New Futaba sv servos
Quick question if I may,
These servos are listed as requiring a 7.4 volt supply, which is essentially a 2s Lipo. Fully charged lipo RX packs are at 8.4V, but they drop down quickly when you start pulling a lot of current out of them, so a freshly charged lipo shouldn't be a problem.
However, suppose that I want to use the BEC on my new Mezon controller to keep my RX lipo pack charged at 8.4V, and also supply redundant power to my receiver at 8.4V. Would this be a problem for these new HV SV servos?
I know that I could regulate my BEC down to 7.4V, but then my RX lipo pack wouldn't be kept fully charged, so there is potential benefit in setting the BEC at the highest voltage.
Brenner ...
Brenner ...
Jim O
PS: You need a Jeti DC-16 to go with that Mezon. Great TM data and a lot of other stuff.
Hey Apereira,
Thanks for the reply.
What I would like to do is run the BEC from my Mezon ESC directly into my Futaba S.bus receiver, and then run the second BEC lead into the back of a Digi switch with a small 2s lipo in parallel. The idea is to use the lipo as a redundant backup that's kept fully charged by the BEC set at 8.4V.
However, I realize that the BEC is going to maintain the voltage at 8.4V, regardless of the current draw from the servos, so I need to know if these new SV servos are safe running at a constant 8.4V.
If they are not safe, then I can adjust the BEC voltage back to 7.4V, but this won't keep the Lipo fully charged.
Brenner ...
Brenner ...
Hi Brenner, the Mezon specs the BEC out at 8.0 volts max. I'm essentially running the system you stated but with the BEC at the 8.0 volts and cheap HV servos, the BEC keeps the 2s pack charged to 8 volts, or about 75% charged. The setup worked great this season.
Dave Snow
Dave Snow
Jim O
Jim,
A short in any ser o power wires will kill the system regardles, I have seen it with sohrting servos 8711, it was due to impropper installation, but seen it twice.
Hi Brenner,
I do understand your setup, you will take advantave of the BEC and that will maintain the 8.4V, but I have not been able to confirm the voltage, but let's suppose someone uses a 3000mAh Rx batt, that on an F3A model will probably hold the 8.4 or 8.2 at least for about 4 flights, so we could assume, that they should be able to support it no problem, is the Rx overheating if wrapped in foam for example, I mean certain colling precautions should be maximized. Anyway, the Japanese page say they are designed for 2S LiPo, so you should be ok no matter what.
regards
Hi Brenner,
regards
#31
The HV's are fine on Lipos. I run 9 of them in my Carden Pro unregulated for the last two season. I plan on running HV's on my new pattern planes for next season also unregulated on Lipos. The only thing I am going to do is run heavier gauge wire.
#32
Hi Alejandro,
I got these some time ago for a foamey ;
http://www3.towerhobbies.com/cgi-bin...&I=LXSWC4&P=ML
I have had a good look at one today and I have to say I'm tempted to use 4 of them for ailerons on my new model. They would be ok on elevators as well.
I am talking electric- contra - soft mounted. ie; 4 X 2.4 = 9.6Kg torque - plenty and especially with light wings.
The weight saving is very very significant ; 6 x 10g V 6 x 26g --- 96g saving.
The money saving is not to be sneezed at either ; 6 x $40 V 6 x $140 --- $600 saving.
ie ; if used on elevator as well.
Have also considered using 2 of them per aileron - ie 19.2Kg torque and only 20g per panel.
I think that I will come back to this for my new model - Version 2.
Anyway for now I have decided to go with one of these two ;
http://www.savoxusa.com/Savox_SH0254.../savsh0254.htm
http://www.savoxusa.com/Savox_SH0255...avsh0255mg.htm
I will get one of each to help decide which is best. A gear set will convert the rejected one.
Still a 40g and $400 saving on aileron alone with almost 16Kg torque - can't be bad.
Edit; I mean to add for reference purposes that a pair of S9154's had 9.2Kg torque and we were very happy with those on a 5.4Kg YS powered model.
Brian
Brian
#33
My Feedback: (53)
I had 4 savox in my Miss Wind ailerons for a little bit and I took them out they some play when they were new which I could live with, but they all develop quite a bite more in a very short period of time...talk to Savox they didn't seem to care much and no nylon gear are available to replace the metal sloppy one.....they we're replace with 4 Futaba, couldn't be happier. (No JR that size)
#34
Brian,
I agree they are big savings, but the power on a servo like the 153 and on (as the 173 it's pretty much the same servo with different electronics) is not to just move the aileron to the extreme, is for moving an aileron about 5mm with presicion and when it returns to center to do it with enogh power it can get to the exact same position, to me move a
surface with great presicion means you need power.
If a version of the servo would exist with 65oz it will be the choice, but this is what they produce, besides the fact the gear train has to be appropiate to take those loads, specially on the YS185.
cheers
cheers
#35
I was afraid that someone might have bad news on these - thank you all the same.
What model savox did you have ??
Somebody showed good test results for savox on here some-place last year ??
Edit; And what Futaba did you replace them with.
Brian
#36
My Feedback: (53)
I had the SH-0256 x4 in the wing...they we're replace with the S-3156 which are still very good after 50 flights or so....and 2x SH-1350 has dual elevators.....which I'm changing this winter they have also develop excessive play after just 50'ish flights the only Savox I like Is the SC-1258 on the rudder...this is in my Miss Wind S
The elevators were setup with a single SC-1258 at first but I wanted more setup options....so I change them when I change the wing servos.
I'm returning to flying after 11years or so...and got hookup on F3A all over...I used to Fly pattern pretty much exclusively.....when I say excessive play that might be fine for some it's subjective opinion
#37
Daniel,
Thanks.
Slop at centre is the last thing we need.
I assume the Miss Wind S is 'E' power.
Brian
Edit; The gears in those 0256 are a mix of plastic and metal according to their web site ??
Thanks.
Brian
#39
My Feedback: (53)
Serious Pwr Yap upon my return to RC I swear no more nitro or gas stuff.....so far it's working very well
TimB- Yes I guess the time that you could buy the same servo with plastic or metal gear seem to be gone, but I don't find play in the JR and Futaba...at least not that much...and there is no way I'm going to change the gears after every 50 flights on an electric plane.....that would have mean like 5 set of gears per servo's this past summer, and I didn't fly that much
These new Futaba look sweet like the new JR
#40
1 Post
Are you saying you see play in the Savox servo's? I don't experience much of that. Which Savox are you using?
I fly gas engines btw and don't have problem with gear wear on Futaba, JR or Savox. Metal gear servo's need a bit of play to allow the grease to move about and lubricate the gears. If there is no slop in a metal gear servo, then it WILL wear quickly since as the gear teeth heat they will bind more and squeeze the grease out. A small amount of slop is not noticeable if the actuator linkage is set up correctly for pattern
#42
MN
Futaba changed from SBUS to SBUS2.
I picked up these BLS174HV S-BUS(1) on sale.... knowing that they would be replaced with same servo but SBUS-2...
The question I have is, the SBUS-2 servos also have METAL GEARS.
couldn't I place the metal gears in my SBUS-1 servos???
I didn't see it for sale at Tower....
#43
Hi,
On doing some research this evening there seems to be a possible issue with deadband width and savox.
Their better ones have a deadband of 3 μsec and the smaller ones 5 μsec.
It is claimed that JR and Futaba have narrower deadband widths - but finding specifications is proofing futile.
Brian
Brian
#44
My Feedback: (53)
#45
Dead band on Futaba S.Bus2 is in degrees, 0.03 deg to 3.98deg, 0.03 is exagerated as it will probably just increase current draw and maybe shorten the servo life, the standard setting is 0.16deg, at that setting you can hear the servo motor working without really moving the stick, just with a very very slim movement.
Kochj,
Yes, YS185
Kochj,
Yes, YS185
#46
1 Post
Sorry I didn't want to spark off a fight. I just asked which servo's you were using because the servo number you lists belongs to a mini servo which is not really suited to power planes let alone ailerons on such aircraft. They're better suited to gliders and smaller electrics due to having only bearing on the output shaft. Even the S3156 are not suited to a aircraft the size of a Ms Wind and are rated at only 2kg.cm. Just really confused as to why you woudl go this route for a pattern plane when there are better suited wing servo's available.
#47
MN
Didn't know that Yamada, was increasing the cc's on there current line....of 175's.
Anyone know if you can get replacement gears for the BLS174HV ( sbus1 VERSION )?
Would like to have metal gears for durability...
#48
My Feedback: (53)
I still think that you got what you pay for and Savox was a mistake that I won't be making in the future.
#49
you should stay with the nylon gears, they are actually more durable unless you hit the aileron accidentally with something.
The YS185 was flown in the WC, I got mine before the worlds but had to cancel my trip due to business. it should be out soon.
#50
The plane never flew right with that servo on the rudder, very hard to keep the vertical uplines straight and needed 3% of throttle to rudder mix.
I changed it with a Futaba BLS451 and all the problems disappeared, mix reduced to 1% and the gear slop is almost non-existent.
