Thunder Tiger 120 Pro question.
#51
Very cheap in the UK: 69 pounds
http://www.sussex-model-centre.co.uk...Engine-940.htm
#52
Swill,
Your engines RPM number indicate the optimum prop to be an APC 16.5x11 (APC 16.5x12 -> repitched to 11). Another consideration would be an APC 17x10N, the prop chart shows it to be at the high end of the load, but still capable of 8400 rpm.
_________
Schpankme
_________
Schpankme
#53
Got verry verry broad needle.
Seems to be my problem as well.
How much should i cut off the header..,
got mine for 155 pounds. thats for engine, header and tune pipe
Runing it with a 15 -12 at the moment doing 8400 rpm but it can do more because it was not on idle verry well [&o]
#56
Test ran my new engine with a MA 16x10 with straight header, no pipe and was turning 9030 rpm. Plan to be using an APC 16x11. Had some problems with middle range being rich, but will wait till I have the pipe on before I start tweaking the pump.
#57
I will be using mufler tuned pipe for os 90.. will it be enough? that's the only pipe I have, and I like to start the engine in two days.. need to run it -in before practicing f3A leo 110
thanks in advance for your answers guys
nubli
nubli
