Engine Thrust question
NC
I have an old Modeltech Calyso that I am installing a new firewall on. Does anyone know that engine thrust settings I should shoot for? Should I just start with 0-0? What do typical 60 sized two stroke ships run?
Thx
Scot
Thx
Scot
I can't specifically comment on your model, but between 1 and 2 degrees right thrust will suffice for most 60 powered pattern planes.
Lee Davis
[link=http://www.piedmontmodels.com]Piedmont Models[/link]
Lee Davis
My Feedback: (16)
NJ
The directions call for
RT 1.5 deg
DT 1.0 deg
Main wing incidence +0.6 deg
Stab incidence +0.4 deg
CG 125 to 145 mm
I bought my Calypso used and never checked to see how mine was set up but this should give you a start.
RT 1.5 deg
DT 1.0 deg
CG 125 to 145 mm
