Muffler for Mintor 170
Old 11-14-2004 | 06:31 PM
Banned
My Feedback: (-1)
Default Muffler for Mintor 170
Hi Guys,
Just wondering if any of you guys have any suggestions for a good muffler for the Mintor 170. Also any pros / cons in using a muffler instead of a tuned pipe.
Also for you Mintor 170 owners any of you guys experiencing problem in blowing plugs?
Thanks Guys Look forward to hearing replies
Old 11-14-2004 | 07:47 PM
Default RE: Muffler for Mintor 170
I am using the mintor pipe and it seems to run well. You will lose power with a muffler. You will have to do less tuning wth a muffler
Old 11-14-2004 | 08:58 PM
Agilefalcon's Avatar
3M have a new pipe (aluminum) and Aeroslave have a new carbon pipe for the motor. Both are available from www.aeroslave.com
You might want to try Zimmermann for custom headers and pipes if you are not looking for a tuned pipe.
Old 11-15-2004 | 02:01 AM
I have used the Bolly muffler and it still has awesome power run a 15.75 X 13 3 blade on a Focus #1 at close to 11 lb. made a much better plane out of the Focus, not sure but I think the 590r Bolly isn't being made right now and very hard to find, I have heard that Bolly might start production again on the 590r.
Steve Maxwell
Old 11-15-2004 | 12:22 PM
For me the best pipe is Mintor's Alluminium Pipe only 95g and a ton of power.... transition min to max Perfect!!
ID:	193143   Click image for larger version
Old 11-15-2004 | 05:47 PM
fonzie72, does the throttle servo mounted on the mount like that wear alot? or does is stand up to the vibration good?
Old 11-15-2004 | 08:23 PM
Pro pattern's Avatar
Hello There raptor5900,
I’ve don the same with My set-up.
I’m using An Webra 160 Aero Xp Mounted on a A-type Mound.
I’ve copied this idea from Bob P. ass I thought it was an excellent idea.
Till now I haven’t got any trouble with this set-up.
I have about 32 fight or more with this system.
The one thing I notice was that the Servo it self would not get that much
counter vibration, as if it was mounted in side or some where on the plane.
This way the servo will move to getter with the engine.
Hoppe Bop P. will join in, ass he has more experience in this set-up , and also more fight on it.
Hope this is the info you looking for.
Regard’s
Danny Koolman
Old 11-15-2004 | 09:02 PM
Here is a couple of Pic.
ID:	193300   Click image for larger version
Old 11-16-2004 | 06:11 AM
Hi raptor5900,
There is no problem with this set up , the servo move togheter with motor vibrations, I have over 60 flights with no one problem, My Hide's Motor Mount is a ARIA for YS140, harder with little vibrations, ciao See soon Alfo
