Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Which stick mode is the best for F3A? >
View Poll Results: A poll
rudder/gas - aileron/elevator
46.79%
aileron/gas - rudder/elevator
53.21%
Voters: 109. You may not vote on this poll
Old 02-21-2005 | 02:52 PM
SCJ
Default RE: Which stick mode is the best for F3A?
If I remember correctly Chip flew single stick with a Futaba 512 TX. When they made the Futaba 1024 TX it was not available as a single stick so he then flew competition with the 2 stick TX.
Old 08-30-2006 | 02:01 PM
RVM
Out of curiousity, is there any way to change the mode of a tx? Say, from mode 2 to mode 1? I guess you could just plug your rudder servo up to the aileron channels, and so on and so forth. Might lose some programming capability designed specifically for either aileron or rudder though.
Old 08-30-2006 | 03:09 PM
Dunno about others, but JR9Xii (9303 in USA?) is simplicity itself---you just select the mode in the programming, and move the throttle leaf spring(choice of two---click/no click) from one gimbal to the other.
Old 08-30-2006 | 03:58 PM
RVM
I can do that with my 9303?? Sweet! [X(]
Old 08-30-2006 | 04:08 PM
Forgot to add: and the coil spring from one gimbal to the other one.
Old 08-30-2006 | 05:12 PM
  #31
RVM
So this means I can change out the ratcheting mechanism too yes? For instance, I could order the heli ratcheting thingie to replace the airplane ratcheting thingie, and thus have the smoother movements yes?
Thingie is, by the way, a very technical, jargon-steeped term!
ORIGINAL: f3a05
Old 08-31-2006 | 03:03 AM
  #32
Yes.
(The Tx I have here had the smooth one already installed, and the ratchety one was a spare in the foam box it came in.)
Old 08-31-2006 | 08:45 AM
  #33
RVM
Awesome. I'm going to try putting my aileron on the left stick and the rudder on the right (throttle/aileron and elevator/rudder).
Thanks!
ORIGINAL: f3a05
Yes.
Old 08-31-2006 | 10:30 AM
  #34
JAS's Avatar
JAS
OK, quick check. What are the modes?
---------- Left stick-----------Right stick
Mode 1: Elevator/Rudder, Throttle/Aileron
Mode 2: Throttle/Rudder, Elevator/Aieron
Mode 3: Throttle/Aileron, Elevator/Rudder?
Mode 4: Elevator/Aileron, Throttle/Rudder?
When I was in Japan, I flew a foamie on Mode 3? (Thr/Ail, Elv/Rud) which wasn't too bad. At least if I started flying Mode 2 it was just a rudder turn. While I was at the Nall, I got to fly a 3.3 Yak that was Mode 1? (Elv/Rud, Thr/Ail) and was able to so ok with it. That's what the "happy" pic in the MA was... but we were all laughing cause I think at the time I reverted back to Mode 2. Very fast dive with a very big plane is funny... when it's not yours. Guess it's what you're used to.
Old 08-31-2006 | 11:11 AM
  #35
RVM
Oops I got my modes mixed up. Thanks for the clarification! You learn something new everyday...
Mode 3 is what I wanted to try. Mode 1 wouldn't work with my 9303 anyway because of the single analog trim level for the throttle.
ORIGINAL: JAS
Old 08-31-2006 | 01:32 PM
  #36
Something is wrong here
Mode 4 is
left stick: aileron/throttle, right stick: elevator/rudder
Old 08-31-2006 | 01:33 PM
  #37
RVM
I've read all over the place on this one.
I'm going to try what you describe as mode 4.
ORIGINAL: Zaquron
Mode 4 is
Old 08-31-2006 | 01:39 PM
  #38
I'm flying Mode4 with reverse throttle. How does that add up?
Old 08-31-2006 | 01:42 PM
  #39
RVM
-Mode4?
ORIGINAL: Zaquron
Old 08-31-2006 | 03:20 PM
  #40
grotto2's Avatar
Some years ago I switched to what I call mode 3 and it matches Jason's description. This is Kristensen's mode.
For some reason though, Futaba designates this as mode 4. I don't care they call it as long as I can get there, and some of the cheapest Futabas have no problem being programmed this way.
Be careful scrolling through the modes. I had a 'woopsie' the other day with an electric!
-Ron
Old 08-31-2006 | 03:31 PM
  #41
You know there is one big problem with flying a different mode:
When you want a pilot better than you to help with your model wether its trimming, or in an emergency you are not going to get the help you need or want.
Then again if you are already the expert then this should not matter.
There have been TOC, Nationals, World Champs flying Mode2, flying Mode1. I don't thing the mode has much to do with the how well you fly just that you do.
Old 08-31-2006 | 03:44 PM
  #42
RVM
I just want to try different modes to see which I like best.
Mode4 seems most logical to me - group the rudder and elevator on one hand and the aileron and throttle on the other.
ORIGINAL: AAM1024
Old 08-31-2006 | 03:55 PM
  #43
8178's Avatar
My Feedback: (17)
Interesting of the two poll choices mode 4 received the most votes so far.
Old 08-31-2006 | 05:13 PM
  #44
can773's Avatar
ORIGINAL: grotto2
-Ron
Ya Ivan calls it mode 3, and everything else calls it mode 4.....not sure who is right but Ivan has been flying it a long time
I made the switch about 7 years ago....and have converted a lot of guys to flying that way. I think its a fantastic way to fly for pattern. I am sure it has allowed me to improve in areas that I would not have been able to if flying mode 2....I am just not talented enough to fly as good with mode 2.
Old 08-31-2006 | 07:37 PM
  #45
patternflyer1's Avatar
Jason is correct
Mode 3 is throttle aileron, left stick, rudder, elevator on the right stick. Provided that you know which hand is your right hand. LOL
This is the mode I fly and have always flown. I have to get my radios rewired as here they don't offer them in mode 3.
I can't say it's better, but it has it's advantages in rolls IMO.
Old 08-31-2006 | 10:04 PM
  #46
RVM
Ok, so mode 3 is what I want to try then? *sigh*
I wonder if I'll have to rewire my 9303. I really, really hope not! Let me go look at my manual again...
ORIGINAL: patternflyer1
Jason is correct
Old 09-01-2006 | 03:00 PM
  #47
grotto2's Avatar
So RVM's junior radio won't do this? And patternflyer1 says Airtronics won't either??? There's really no excuse for a computer radio being unable to program to mode 3 nowadays.
Radio South used to rewire mine for a nominal fee in days long passed. Give them a try.
Old 09-01-2006 | 07:24 PM
  #48
Adamg-RCU's Avatar
The JR 10X requires that the connectors going to the trim tabs and stick pots be switched around. Not as easy as in the 9Z, but can certainly be done at home.
Old 09-01-2006 | 09:15 PM
  #49
RVM
Got a link or pictures? I'd like to try this.
Old 09-01-2006 | 10:18 PM
  #50
Adamg-RCU's Avatar
No, sorry. The hard part is getting the 10X's back off. Once inside you'll see a bunch of small white connectors with 2 or 3 wires each. Just trace them to the trim tabs and pots that you want to switch, and switch them.
