CGM ultimate 10-300 mods
Old 03-20-2005 | 12:10 PM
Default CGM ultimate 10-300 mods
I have posted some questions in [link=http://www.rcuniverse.com/forum/Chip%25%25%25the_Ultimate_question%25%25%25/m_1428529/tm.htm]Chip Hyde's section[/link]
but wanted to open the discussion for more opinions.
I'll appreciate your thoughts
Ad'
Old 03-22-2005 | 01:27 PM
Default RE: CGM ultimate 10-300 mods
Hi Guys ,no thoughts on this matter?
Old 03-22-2005 | 03:35 PM
Counting Chip, this is your THIRD post on the SAME exact question. They are ALL current!
Chip has already answered you--------see my comments on this SAME post under Aerodynamics!
Old 03-22-2005 | 04:33 PM
I've built 5 CG Ultimates...here are the mod's I would do, in no particular order:
-Fiberglass cowling and wheelpants from Stan's Fiberglass...ask to make them "contest light"
-Aluminum gear from fiberglass specialties, but NOT the cowling, etc...heavy white fiberglass with pinholes...
-barn door the ailerons...i.e...box them in with aileron stock about 1 inch at the tips
-plywood reinforcement at the cabanes on the upper fuselage piece
-taper the tail surfaces with a razor plane
-use 6 inch wide balsa to sheet the tail to avoid having a wood seam
-ditch the crappy engine mount for an aluminum one
-YS 1.40 all the way!
-goes without saying...two aileron servos instead of the one
-cut off the rear plywood turtle deck sheeting and carve balsa farings so you can assemble the plane after covering
-Some extreme mods:
-thin the sheeting on the wings and tail to 1/32 instead of 1/16
-cut out new balsa top and bottom for the fuse to save some weight
