What size batttery?
Old 08-08-2005 | 05:49 PM
flyinrazrback's Avatar
My Feedback: (69)
Default What size batttery?
what size lithium are you guys using in your 2m planes? My plane has the futaba aileron servos in the wings, futaba mini digitals in the stabs x2, 9151 on the rudder, and standard on the throttle. What size would you recommend? I usually only fly 4-5 times per day. I currently have a thunder power 900 and a TBM 2800, however the TP is 2oz lighter.
Old 08-08-2005 | 06:21 PM
toddblose's Avatar
My Feedback: (10)
Default RE: What size batttery?
I am using a Thunder Power 860 2 cell on my Electirc Genesis. I have it regulated
to 5.6 volts and get around 8 flights. In the past I used the 1800mah nicads but
with the Thunder Power I get more flights and with less weight.
Old 08-08-2005 | 06:50 PM
Adamg-RCU's Avatar
Expect to use ~150mAh per flight with a glow plane using digital servos.
