Python 2x2
Old 12-03-2002 | 01:07 AM
Default Python 2x2
I've got a python 2X2 pattern ship with 1100 square inch wing ( large ones), and I noticed that the trailing edge is 90 degrees from the wing root line, unlike the actual drawings ( plans ) show, where they have some taper..
The question is, do the 1100 sq. inch have no taper at all in the trailing edge ?
Thanks in advance
Juan C.
Old 12-03-2002 | 02:40 PM
J roc's Avatar
Default REFINED
I believe Henry Piorun made these changes after the original design (on the plans) so you have the newest version. Im not sure exactly why but I believe the straight trailing edge tracked better but possibly sacrificed its snapping capabilities.
Old 12-03-2002 | 04:39 PM
Default Re: REFINED
Thanks Red.
Why do you believe that snap capabilities are reduced with the trailing edge straight ?
Old 12-03-2002 | 05:46 PM
J roc's Avatar
Default snap
with the tapered wing you have less surface area at the wingtip and the average wing chord is swept forward slightly so it is easier to induce a stall. Most aerobats have a double tapered wing for this reason.
Old 12-03-2002 | 10:27 PM
My Feedback: (10)
Default Python 2x2
Maybe for CG considerations? it will lengthen the nose moment with a straight trailing edge and shorten it with the tapered TE.
Regards
Bill
Old 12-04-2002 | 12:13 AM
J roc's Avatar
Default Python 2x2
thus allowing a lighter engine. Absolutely.
