Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Pipe and Header Needed for a Webra 145AAR >
Old 04-07-2006 | 11:40 PM
My Feedback: (24)
Default Pipe and Header Needed for a Webra 145AAR
I am using it in a Hydeout. I think I will need a 1 1/2 inch rise. Not sure of the length of the pipe though. Please help!!! Thanks.. John
Old 04-09-2006 | 06:00 PM
Default RE: Pipe and Header Needed for a Webra 145AAR
Hey RareBear,
I am using the Johnson header from Central with the Webra pipe from Horizon with my 145 on my Focus I. My header has the 2.25 inch rise (or drop, depending), I believe Johnson makes a 1.5 inch, also available from Central.
I have mine set for max length of the Focus pipe tunnel. Will measure it if you want.
Also, I have the Aero Slave pipe to use on my Webra 160/Johnson header for my Brio; Aero Slave suggests 30 inches overall for the 160. Could be different for the 145.
Since the original post, I have measured the length of the 145 system: straight line from glow plug to end of pipe body (not including stinger)--32 3/8 inches.
Jim
