Y Harness for pattern?
Old 05-04-2006 | 10:35 PM
jzinckgra's Avatar
Default Y Harness for pattern?
Quick question. I am finishing my pseudo pattern plane (dream 110) and was wondering if using a y-harness for the aileron servos is a no-no in the world of pattern. I am using futaba digis. I won't be competing, if it matters. thanks.
Old 05-04-2006 | 10:55 PM
My Feedback: (9)
Default RE: Y Harness for pattern?
it will work ok, but most computer radios you can mix 2 channels together so you dont need a Y harness
Old 05-04-2006 | 10:59 PM
I don't see why not, someone else may know better then me. Only thing I can think of is you will have to achieve ail differential the old school way, mechanically.
Old 05-04-2006 | 11:24 PM
If you use a Y harness, you will not be able to adjust ATV individually with your radio
Old 05-05-2006 | 02:30 AM
Yes, you may use a Y harness but it is not the optimum way to do things. As stated by the others, you will have a lot of mechanical work to do to set up the plane right (getting the correct differential, the same throws each side, etc). And each time you have to do a minor adjustment, you will have to do it mechanically. In other words, as long as your radio has a flaperon functio, there is no reason to use a y harness. What radio do you have?
Old 05-05-2006 | 12:03 PM
jzinckgra's Avatar
I have a 9CAP. I just hate having to plug two servo plugs into the RX every time I put the wing on or off. Or should I just use two 6" extensions, plug those into the RX and leave those there all the time? then i'll just connect the plugs from the wing to the extensions.
Old 05-05-2006 | 12:05 PM
I use the extentions out of the reciever. just plug into extentions and don't mess with the reciever connections.
Old 05-05-2006 | 12:32 PM
bokuda's Avatar
My Feedback: (7)
Suggest that you label the extensions from the rx right and left.
Old 05-05-2006 | 02:11 PM
My Feedback: (9)
I have extensions, you wont have a problem
Old 05-05-2006 | 06:56 PM
I use extensions and just mark the channel one extension and the servo lead from the right wing with white tape. Then I just plug both wires with tape together and both without tape. Simple, easy and works every time.
Old 05-05-2006 | 07:09 PM
My Feedback: (85)
I got my extensions from Electro Dynamics in different colors. hook up the same colors and that way it's a no brainer. Of course with my small brain it's needed.
Old 05-05-2006 | 07:47 PM
jzinckgra's Avatar
thanks guys. bought some extensions tonite.
Old 05-05-2006 | 10:56 PM
klhoard's Avatar
My Feedback: (10)
ORIGINAL: jayjayneri
I just put a knot in both right aileron wires. . . of course this also works for the left. . . but not both. . .
