Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
Reload this Page >
SURPASS-90 Pattern Plane - Has anyone heard of them before?
Old 01-06-2007, 07:34 AM
mikedsilva
Default RE: SURPASS-90 Pattern Plane - Has anyone heard of them before?
bjor, out of curiosity, what was the other THS plane that you bought?
mike
Old 01-07-2007, 02:05 AM
mikedsilva
Here are a couple of photos of my Surpass 90 out of the box...
ID:	592515   Click image for larger version
ID:	592516   Click image for larger version
ID:	592517   Click image for larger version
ID:	592518   Click image for larger version
Old 01-10-2007, 07:00 AM
mikedsilva
wagen
what sort of soft mount did you use?
i have a dave brown soft mount (rail type) but when installed, it raises the engine off the bearers too far so that the crankshaft does not line up with the centre of the nose cone. It seems that the only way i can soft mount it, is to have an altered thrust line... otherwsise i am thinking of beefing everything up with glass cloth and hard mounting the motor...
Old 01-10-2007, 09:52 AM
wagen017
I mounted the engine directly to the hardmount of the plane, but raised this by adding some ply in between (otherwise it did not line up as well). To reduce noise and vibrations, I overdrilled the holes and used rubber D-locks to mount the engine. To ensure that consequently the engine did not fall out one day (I was not so convinced that the D-locks wil actually hold the engine in place overtime) I used longer screws which after passing thru the D-lock screwed into a plate. Hope this helps.
Here a picture of the engine mounted with the original screws supplied (this was before I replaced this, and added the D-locks). You can see the added ply.
Old 01-10-2007, 03:27 PM
.:RClunatic:.
My Feedback: (21)
i was going to pull the trigger on this infinity copy after fliton discontinued the infinity but now fliton says they are coming out with the Inspire 90! Yipeee! I have a saito 125 that was waiting for a new home. if its anything like their inspire 60, wowzers!
Old 01-10-2007, 03:40 PM
  #31
mikedsilva
is the inspire line of planes more of a 3D aerobat than the Infinity?
Old 01-10-2007, 04:31 PM
  #32
wagen017
much more 3D
Old 01-15-2007, 02:13 AM
  #33
.:RClunatic:.
My Feedback: (21)
not this one, this one is strictly built for pattern. my buddies saw it at the ama show this weekend and they are all in love!
Old 01-15-2007, 02:38 PM
  #34
wagen017
No, No, No, NO!!!! Don't tell me this, RCLunatic!!! Because if it is true, I HAVE to buy it!!!!! Aaarrrrgggghhhhh!!!!!
Old 08-02-2011, 07:51 AM
  #35
yves_83140
Hello, I am new to the forum:)
I just bought a surpass90 and I plan to mount a os95ax, what type of exhaust pipe did you use to integrate a resonator?
PS: sorry for the syntax, I use google translation
Yves
Old 08-02-2011, 08:37 AM
  #36
wagen017
I used a tuned pipe, but it is not so easy since the wing is one piece (I assume it still is).
I would suggest to use the standard exhaust, but don't know if it will fit right away.
Volkert
Old 08-02-2011, 12:07 PM
  #37
yves_83140
I would like to use a tuned pipe but I do not find the connection to return under the fuselage, the 95ax is a lateral exhaust. It should be a pipe in the shape of S and more elevated.
Old 08-02-2011, 12:45 PM
  #38
wagen017
I used a Merker pipe and header. You can find them at http://www.merker-modellbau.de/System.htm
I guess Hatori would have a solution as well.
Volkert
Old 08-02-2011, 01:02 PM
  #39
yves_83140
Thank you
Old 08-02-2011, 09:12 PM
  #40
wagen017
that was on a OS-91 FX. You best send them an email of what you want, let's see if they have a solution.
VOlkert
