patternship
TX
if you are looking to build, check out the insight, pentathlon from www.insightrc.com
try out the black magic from www.customairframes.com
Chuck
Chuck
Hi
sorry I meant taller. I had a look at the Oxai Models Beryll GP.
what is the plane like to fly and will I be able to use it from advanced to F3A
Rael
Rael
My Feedback: (45)
The other problem with the Beryll is that it is 3000US, the Focus is only 749.00. The Glow version is not available yet either. The Focus will comfortably fly the Masters sequence and flies the lower classes better than the Beryll, simply because it is not as tall and doesnt crab into the wind as badly as the newer birds. The new planes are designed for F3a, not the lower classes, sometimes the latest and greatest F3A ship isnt the best for the lower classes,
The Beryll is a great flying plane, however the Focus is more than enough for anything but the new FAI schedules.
Arch Stafford
Arch Stafford
TX
If you can still find a genesis, they are proven airworthy or you should go with the new Shinden or Integral. there are build threads on each of these fine models.
Good Luck.
Chuck
Good Luck.
Chuck
