Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 ES composites landing gear availability? >
Old 05-09-2007 | 12:37 PM
Default ES composites landing gear availability?
After 190 flights, the ES composites landing gear on my Brio is starting to delaminate on one leg. No fault of ES -- our field is thick grass that decellerates the plane like Velcro and really torques the legs.
I'd like to replace the gear with a new set, but can't find anybody that carries the 9.25" high version - "Type B". Central Hobbies only carries the 6.75" high version - "Type A". Central says that ES stopped making the Type B version. I left a call with the ES's answering machine but they're not returning.
So does anybody have an extra set of ES gear they'd be willing to sell? Or maybe suggest an alternative? I need something around 9" tall for prop clearance (E-power).
TIA,
--Derek
Old 05-09-2007 | 12:54 PM
Default RE: ES composites landing gear availability?
I think they're made by Mr Mach in Czechoslovakia----Wolfgang Lorenz in Germany stocks them in lots of sizes (www.f3aLorenz.de on Google finds him).
Only problem (even from here) is payment---Herr Lorenz doesn't do cards or Paypal.
Old 05-10-2007 | 06:31 AM
This is not really a problem.
You tell him what you want, and he sends you an invoice by mail.
The invoice includes all his banking details. It is then easy to transfer money straight to his account, and he will ship once the money is through.
Done it several times, 100% reliability.
Magne
Old 05-10-2007 | 10:15 AM
Don't get me wrong,I'm not criticising Herr Lorenz.
Perhaps it depends on which country you're in, or which bank---but from here(UK), the bank charges are prohibitive for what amounts to pressing a few buttons in the transaction you describe-----------for something relatively small like a U/C it was more than 50% of the invoice price.
Old 05-10-2007 | 09:22 PM
patternflyer1's Avatar
central hobbies in the us carries the es composite gear.
Try them..
Chris
Old 05-10-2007 | 11:50 PM
GDAVIS's Avatar
Derek,
I was looking for some tall gear myself and came across the Chief Aircraft website. They have alot of CF gear and if you click on the photo link it gives dimensions.
here is the link [link]http://www.chiefaircraft.com/rcmsec/Models/Accessories/AirframeAccessories/LandingGear/Graphtech.html[/link]
Greg
Old 05-11-2007 | 12:27 PM
Chris, as I said in my post, I called Central and they don't have the tall gear. --Derek
Old 05-11-2007 | 12:28 PM
Greg, wow. Quite a selection. I'll check it out. Thanks. --Derek
Old 05-11-2007 | 01:47 PM
Anthony-RCU's Avatar
Check Troy Built models website they also sell Graph Tech gear and have more specs. Then look closely at weights. The Hanger Nine 27 Percent Extra is close but over 5 ounces! Have heard some rumors of delamination as well.
Have heard some positive about the Genisis E gear but good luck getting them.
Old 05-11-2007 | 02:50 PM
From some personal experience of making CF landing gear,for 2M pattern planes, legs made with predominantly woven cloth,twill or normal weave, will eventually delaminate.
Legs with unidirectional cloth,(along the long axis of the leg), like the Bolly or ES stuff, do better.
Just my experience, but the common ES patterns,with the little "reinforcing" bulge at the fus/leg angle do eventually start to crack near the bulge.
If you can afford the extra weight, and the mount plate/fus can take the extra shock loading, there are some legs on the Lorenz list, no. 544,which are rated nominally for 7Kg models, which are definitely more durable than the no.545,which are the usual ones supplied for electric flight with things like the Abbra or Leviosa.
They are around 160g as against 110 g, though, and have 20 mm less height---but still enough clearance for a 22" prop, on those models at least.
Old 05-11-2007 | 10:46 PM
Here's link to Bolly if your interested the long may fit your needs. Fast service and in US. http://www.aeroproduct.net/
Steve Maxwell
