Webra 160 supplier
Old 10-27-2007 | 03:24 AM
Default Webra 160 supplier
Where can I get a Webra 160? Is it a good runner? What is the exhaust timing? Which prop?
Regards Rod
Old 10-27-2007 | 06:33 AM
Default RE: Webra 160 supplier
http://www.horizonhobby.com/Products...ID=WEBE1058XPM
http://www.centralhobbies.com/Engine...a/webrtxt.html
I have two of them and will by a third this winter. Once I learned how to set up the Mixture servo curve properly the second setup was easy. With the MC carb I can adjust the mixture in flight witch works great.
Im flying the Ultra RC Evelutiion With the Webra 160. Currently building the Focus II with the same engine. I fly with 2 other guys who have the same setup. Dale Aronald has been winning with ths setup. I have done well in the last 3 contest.
I run the APC 17x12 Dale uses the APC 18.1x10
Muller custom header and ES tuned pipe. I run 10 % cool power , Dale runs 20% with 2 head shims.
ID:	791390   Click image for larger version
ID:	791391   Click image for larger version
ID:	791392   Click image for larger version
Old 10-27-2007 | 06:38 AM
Hi
Ihave used the 160 webra with sucses fore 2 year now
i have found out : 18 % oil 10 nitro . 72cm at a Greve pipe ( from cylinderhead to first plate in tune pipe)
and a 4bl APC 15,5 12 most importen is the is VERY GOOD colling
in a IMPACT and Genesis and now a ZN TWISTER
Old 10-27-2007 | 05:22 PM
My Feedback: (121)
The Horizon website shows the engine as being discontinued. Does this mean Webra has stopped making them or nobody in the US wants to import them? Is Webra going to release a new, larger 2-stroke engine?
Old 10-28-2007 | 03:29 AM
you can get it here
http://www.centralhobbies.com/Engine.../webra160.html
Old 10-28-2007 | 09:48 AM
grotto2's Avatar
I don't think they stock the complete engine there, Torben. Just the parts.
I suppose you could buy all the parts and build a Webra like a kit.
It's a funny place, Central.
They don't have any kit airplanes, just ARFs and they don't have any built Webras, just kits.
Old 10-28-2007 | 10:36 AM
My Feedback: (40)
Latest issue of Model Aviation carries a Webra ad saying engines available in North America from Swift Electronics [link=http://[email protected]][email protected][/link][email protected] , but when I punch that up I get no connection. I'm sure they're there in Winnipeg, but ... unavailable at the moment?
Old 10-29-2007 | 09:21 PM
MTK
ORIGINAL: grotto2
No way....really?? "Born Too Loose"??
That's just plain funny
MattK
Old 10-30-2007 | 07:41 AM
My Feedback: (121)
Is anybody still importing the Webra 1.60?
The Webra website shows them still manufacturing both the 1.60 and the 1.45.
I suppose you could order from the factory or find a European distributor.
I think they're excellent engines, they just don't seem to have the 'visibility' here in the USA pattern scene.
Old 10-30-2007 | 10:49 AM
MTK
ORIGINAL: flywilly
Well, as far as visibility goes, YS is pretty much killing the others with all their sponsorships. Personally, I love the throttleability of the YS but hate the shake of the large engines. I own the small ones only
Besides a bunch of fellows tried setting the Webras up when they first became available around 2000-2001 and had trouble finding the sweet spot. They tended to run them lean and things broke easily and didn't work right. The bad reputation they got from some vocal people was probably not deserved.
I have always found them fairly easy to set up.... pretty powerful engines that swing big props at very useful rpm. I own 4 in both 145 and 160 flavors. I have found the TN carb to be a bit coarse in adjustment, requiring fiddling when temperature drops or increases 10 degrees or so. They are not set and forget types such as YS or gassies.
I wish Perry made an aluminum body carb because some of the best, most consistent running was obtained with a Perry carb. The body of the perry carb is plastic and distorts enough to bind
MattK
Old 10-30-2007 | 11:54 AM
grotto2's Avatar
There's a lot of power to be extracted from the Webras.
But you have to use a perry pump to replace the backplate pump because it gets too hot.
And you have to add head shims to take the nitro.
And even the MC carb is not as consistant as it should be.
Maybe what we need is a big Dynamix for it!
Old 10-31-2007 | 09:39 PM
MTK
ORIGINAL: grotto2
Never used a Perry pump but did use the carb. Never used extra head shims in any on my webras (just 1 stock piece that came with each) and use 22% nitro/20% oil. Never used the MC; only the TN. I wish that they would make the TN with finer tuning adjustment capability or with mid range needle like the heli carbs
MattK
Old 10-31-2007 | 11:54 PM
grotto2's Avatar
Matt-
Jim Woodward gave me a couple of Perry carbs to try and I figured it was a wash between them and the MCs. I got a lot of Webra intelligence from Jim and Dave Lockhart and the Perry pump was a big step forward.
Still, I seem to learn something new about the Webras every six months or so. In my Ultra Stik test plane a Webra 160 will run like a clock, but I can't get the consistent idle in my pattern planes. Is it the fact that it's mounted on it's side or that the mount isn't as soft?
Hmmm. Dave was mounting his motor control servos right on the engine mount.
-Ron
Old 11-01-2007 | 03:38 PM
My Feedback: (121)
I've run UAV Bully engines for years (I still have another new 1.45) which were basically Webra engines with a 2-plug head and I believe UAV carbs and pumps. The engines always ran flawlessly for me. I wonder if putting an old Bully pump/carb on a Webra would work?? I do own 2 Webra 1.45s, but I've never run them. I hope they continue to be available here in the US.
Old 11-06-2007 | 12:26 AM
I've had contact with Webra in Austria asking about availability of engines and parts. They did not give me the name of a new supplier since Horizon has dropped the 160. However, they did say they would sell me the engine and parts direct. Unfortunately, with the current exchange rate the engine ran about $650.00 US, and a piston and sleeve ran $211.00 US. To me this is way too high. So I guess we have to wait and see if another distributor in this country picks them up.
Old 11-06-2007 | 02:48 AM
I had also looked at getting a webra 160 from Europe but the price is too high (prove me wrong). I can get a YS for the same or a OS 2 stroke for less.
Rod
Old 11-07-2007 | 12:34 AM
grotto2's Avatar
Cheeessseee!
That being said I wonder what I will have to switch to when I run out of parts for the three I have.
I wish YS had a nice two stroke in this displacement. I know they prototyped a 150 because I saw it sell on ebay.
