Futaba 4.8v Servos with Jaccio 5.2v Regulator
Hi,
For the following servos:
9150, 9151, and 9206 Futaba recommends to be operated under 4.8v voltage. I have a Jaccio 5.2v voltage regulator could I use it with the previous servos?
Whats is your opinion/experience?
Thanks in advance,
Nikos
Thanks in advance,
Nikos
Hi Nickolas
I had the same question a couple of months ago, so I posted on the Futaba support forum and got the following reply:
The maximum regulated voltage should not exceed around 5.5 to 5.7Volts
http://www.rcuniverse.com/forum/m_54...tm.htm#5468493
I have been using 5.5V since with no problem. So you should be alright using 5.2V
Serafim
Serafim
I think the 4.8v refers to a 4 cell nicad/nimh that would be around the 5.5-5.7 volt when fully charged, discharged it will be 4.8 volt.
So the regulator is is bringing the lipo down to a fully charged 4 cell level.
Jason
Jason
Thanks for the answers.
I have not much experience with Futaba servos that's why I asked.
Regards,
Nikos
Regards,
Nikos
My Feedback: (45)
Nikos,
I personally run all of the Futaba 4.8 only servos at 6.1V and have had no problems. I even run the 9254 heli servo for my elevator and have had zero problems over the last few years. I've run 9151's as well...no problems,
Arch
Arch
When you say you run 6volts do you mean a 5cell nicad/nimh pack or a battery pack (lipo etc) regulated at 6volts?
Because a 5cell pack is going to be 7.5-8.0v at full charge.
Off topic but I did have the same question to Graupner/JR.
There answerer was that 4.8 V servo from Graupner/JR are specified to max 6,3 V. I have a Powerbox regulator that give 5,9 +- 0,1 V or max value at 6 V. That is OK for 4,8 V servo from Graupner/JR.
/Kristian
/Kristian
An irrelevant question, have you encountered any incompatibilities or strange servo behaviour when using Futaba servos with JR receivers?
Looking forward to replies,
Nikos
Nikos
