Hatori pipe repair
Old 02-04-2008 | 10:20 AM
My Feedback: (55)
Default Hatori pipe repair
Anyone know what kind of temperature a muffler from a YS 1.60
four stroke is subjected to ? I was wondering if JB Weld will hold up
repairing a crack in a Hatori pipe. The specs on the JB Weld package
says it will take up to 500 degrees continuous and 600 degrees for
10 minutes.
tommy s
Old 02-04-2008 | 12:41 PM
Don M.'s Avatar
Default RE: Hatori pipe repair
I made a home made header pipe out of copper elbows held together with JB Weld. It held up fine for the 100 or so flights I put on it. This was on a 26cc gasser, hotter than a 4 - stroke and the first joint was within 2" of the exhaust port in the cly. It will hold no problem if your prep is right.
Old 02-04-2008 | 01:22 PM
My Feedback: (55)
Thanks Don,
I figured it might be OK , that stuff will fix just about anything !!
tommy s
Old 02-04-2008 | 04:58 PM
ORIGINAL: Don M.
I believe you will find that a four stroke's exhaust temp is hotter than a two stroke-----not cooler.
I have tried JB weld with less than satisfactory results on four stroke (unstressed) exhausts.
Old 02-04-2008 | 05:36 PM
Don M.'s Avatar
ORIGINAL: onewasp
ORIGINAL: Don M.
Were talking 2-stroke gas and not glow. I'm not an engineer and I stand to be corrected but my gas exhaust is as hot or hotter than my 4-strokes. Besides I have a pressure nipple JB welded on my Saito .56 muffler and I think it's going into it's 10th year now. As I said prep is everything. If it works it works, if it doesn't it doesn't, what's he got to lose.
