Stream 50 What engine???
My Feedback: (21)
NY
I just got the new Stream 50 pattern plane. I have a couple engines in my position right now OS 46 FX, Rossi 45, YS 63 4 stroke. I want to know what engine will work the best w/ this plane, even if it's not on my list. Here is the spec for the plane
Fuse Length 55.51 inches
Wing Length 53.94 inches
Weight 5.29 lbs - 5.73 lbs
Engine size .53 4C - .63 4C
My Feedback: (21)
NY
I thought the two stroke might work better on the pattern plane...... , I guess Rossi w/ tunned pipe would be too much
P.S. I am trying to save YS 63 for Kyosho Gee Bee .40 witch should arrive soon......
ThanksP.S. I am trying to save YS 63 for Kyosho Gee Bee .40 witch should arrive soon......
My Feedback: (21)
NY
CHassan,
We should talk again in the couple weeks, after you will bring this plane to the air. I was going to buy that plane, but I got the very good deal on the Stream 50. If something goes wrong I would get Sea Bee without any doubt. You have to put Rossi on that plane.
you whould not be disappointed.
Good luck.
you whould not be disappointed.Good luck.
NE
I have YS63 in my Stream 50 and it pulls the snot out of it. I'd say the plane is overpowered with the YS63... you could easily get away with a lot less power if you wanted too.
cheers
cheers
Try a Super Tigre G-51 ring. It's in stock at tower hobbies for $109 and the muffler is said to be so good you won't need a pipe. I had a G34 ringed ST once and it was an exeptionally nice engine.
My Feedback: (21)
NY
Thanks Jon
The cowl on this plane is too good to be cut for 2 stroke engine muffler. On this plane I can use ether 4-stroke or 2 stroke w/ tunned pipe. Thank you.
I had and sold on a Stream 50 Hi Perf. Now have the Stream 90 Hi Perf. I used a YS63 with a flexi manifold and a small torpedo muffler. Looked really great on the plane. I then changed to a small 4 stroke pipe that took the whole bay beneath. It sounded like a sewing machine and went like stink. Bags of power for AA and '3D' stuff with the APC FF paddle prop. The 63 is a great match though might be a bit oo much power. The YS 53 might be just perfect. As for Two Stroke, well.. you really want to cut that cowl up?
My Feedback: (21)
NY
No way, I would not cut that cowl. I decided to buy a Saito 56. I think I can go with the regular muffler, only what I need it's a drill hole in the cowl, but NO CUTTING. Thanks for reply. Good luck.
