aeroslave problem
Old 06-14-2008 | 02:08 PM
Default aeroslave problem
After about 90 fligts (some leans) on my os 1.6/aeroslave black magic the exaust noise changed ,at first I tought that a slicone coupler has broken but after i removed the belly I noticed that both couplers where ok, I then cheked the pipe and I discovered that if I shake it something inside moves and clunk.It means that I need anew one or the pipe can be repaired?
Old 06-14-2008 | 02:13 PM
My Feedback: (16)
Default RE: aeroslave problem
ORIGINAL: ampa
I had the same experience. The internal baffle has come loose. I sent the pipe back to Aeroslave and they fixed/replaced the pipe with no questions. Contact them. This happened to me twice and I eventually changed to an ES Carbon pipe.
Old 06-15-2008 | 10:15 AM
My Feedback: (55)
The same thing can happen to the ES pipe, it's just the nature of a carbon
fiber pipe..... they will all eventually start to soak in the oil from the exhaust.
tommy s
