NEUTRINO - NEW F3A PROJECT FROM GREECE
RE: NEUTRINO - NEW F3A PROJECT FROM GREECE
Alex Voicou ,you look like the right person to draw the fuse front side and wing and stab tips !
It will take some time for me to draw those ,my 3d modelling experience is limited.
Kiting the plane ?..wow I never actually thought about it ,in this case somebody else would have to make the leyups,I would never find the time to do it myself ,we´ll see how it goes ..
thanks
Elias
thanks
Elias
Hi alpback nice to hear from you through here ,thanks for the comments !
Alex from Russia ! Nice to hear from you ,I heard you are setling to Greece soon ,awsome !
I´ve seen Mandrikas plane in Ireland 2001 first time ,I was amazed by his techniques ,two pice fuse is really his thing definately . I remember his double former technique at the splitting point,propably will do something similar with the composite fuse.
Alum part is for several reasons ,First they had to be thin ,maximum 1mm because the inner part (rectangle) has to be as out as possible ,a couple of milimeters double the holding power of the tube ,I´m not sure if I explain this good.Plywood would have to be 2 or more milimeters thick .The other good about alum is that you dont need washers where the 3mm screws are.
Here is a drawing pic
Thanks Gregg !
Elias
Thanks Gregg !
Elias
ORIGINAL: ELIAS SOPEOGLOU
ORIGINAL: highfly3D
this is a cool project... are the wings build up or foam balsa? what engine will go in this plane.
High
High
not only a very cool project but this thread has the most international posts i've ever seen.
#31
Hi Elias,
Thanks for your post on the Defiant thread. Your project is ultra cool and I'm really looking forward to seeing your progress and hearing reports on your first flights of your project. You're a very talented engineer. I wish I new CAD like you and Mark Hunt, you guys are over the top on what your doing. It's just great!!!
Todd
Todd
#32
Hallo Alex
Thanks so much for the offer on the 3d drawings but it,s really not nessesary for that ,the prorotype is already ahead and I would need more time on the cnc mill ,a bit of hand shaping is not a problem on theese parts they are not critical ,
thanks for the offer !
Todd ,thanks for the comments man! I admire your work also with no cad ,but same result.
Here are some pics of the progress ,the steel plates ,also cnc cut with a punching machine,they are used as rulers for cutting the foam front parts
Elias
Elias
#34
ORIGINAL: Buka
HI papaone.
maybe, i am not sure. he has a new design now, the Majest. still 2 peice fuse.
HI papaone.
Elias my friend keep going we watch you....!!!!
#38
highfly3d, the fuse splits for transoprtation reasons,you can practicly fit a plane this size in a suitcase !
Thanks Dave !
Elias
Thanks Dave !
Elias
#39
Here are some more pics of the fuse progress ,the foam block was cut with hot wire using the steel formers.
The nose ring has the hacker motor mount predrilled.
Elias
Elias
#40
My prev plane ,the Oxalys ,fetured a double setup .The front former could either hold a nose ring for the YS or a mount for the hacker that was cut out of stainless steel ,hatori heli silicon mounts isolated the motor.The rest pics tell the story of how the double setup worked .I could change my set up at the field in less than 20min and compare the setups with the rest of the variables virtually the same.
Elias
#42
Here is the battery mount setup ,the landing gear where held with the resonator soft mounts in the glow setup ,theese where replaced by cone head srews holding the velcro stripes on the electric setup
cheers
Elias
cheers
Elias
#44
Did some progress on the wings and stab today .
Here is the stab tube (carbon 12x1mm) ,to make the tight sleeve I wraped the tube with some foil ,waxed it and wraped it with carbon sox.
All epoxy used through out the plane is aircraft grade baked at 60deg C.
Elias
Elias
#45
also ,the fin airfoils cnc cut out of steel plates ,they are not true airfoils ,(never are) but they are as close as possible ,the variable of having to match the bottom part with the fuse makes the change.Perspective photo makes them look a bit ´fat´at the LE.
Elias
Elias
#46
Also ,the canalizer has been machined ,I should have taken some pics during the process but[sm=confused_smile.gif]
here is a pic of the two halfs already joined ,if you look close you can see the toolpath passes just like the simulation ..
I love cnc machines !
#48
Yep,..just very kool,...I just recently finished building my design using similar tools and techniques, mine is called "Serenity" and will be my first electric. Very,..very kewl post!
Bill H.
FTP
Bill H.
FTP
#50
Hallo
Thanks Dave and Bill !
Yasou Mavre !thanks for the comment ,you fly F3A there in OZ Greek buddy ?
Some small progres on the wing ,you can see the wing root airfoil is set with epoxy in position before the wing is cut and serves as a ruler for the cut as well .The tip foil is placed twice with double sided tape for cutting the two half wings.Sorry no CNC here
here is a pic.
here is a pic.
