How prepare Balsa to cover with paint?
My Feedback: (121)
Hi Mike,
Since you're recommending painting equipment (and I haven't bought any new equipment since the '70s when I purchased a 5 hp 20 gallon compressor <overkill>, a DeVilbiss automotive touch-up gun - the Binks gun with the 1 quart cannister<I got free> was too much, and a Paasche airbrush) what do you recommend for a gun (for base color/primer) and compressor? How well do the HVLP guns work?
TIA,
Will
TIA,
Will
What you can get by with and what makes your life EASY are usually 2 different things.
The Devilbiss gun is nice, that should be fine right there. If you want sweetness in a HVLP form, check out a Sata minijet or an Iwata LPH80. Those are the 2 best paint guns for our application that I have found, there are probably others.
Compressor: no such thing as overkill. Install a quality filter/dryer for insurance. You don't want moisture in the line.
Ideally you want about a .8-1.0mm tip/nozzle. Any more really puts out too much paint, any less and you'll really have to thin it and be patient.
The Paasche is fine for trim, just make sure it's clean, lubed and in good working order.
A note about colors: some colors lay down better than others. White SUCKS. It is the hardest to get a good coat for me. So, use the white for setting up and testing. if you can lay that down nice, the other colors will be a walk in the park.
-Mike
-Mike
ORIGINAL: Rendegade
All I'll add to that is made sure you buy a quality roller. Don't think you can get away with one of the dodgy 50c ones, as they have a tendency to throw the roll off and then you're left rolling in epoxy with a sharp plastic stick.
Don't ask me how I know.
Incidentally, Mike have you tried using carbon veil yet? I've noticed a lot of the control line guys using it like tissue. Seems to work well, and I think would reduce the criss cross print through.
Just a thought anyway.
Glass and epoxy paint or thinned epoxy is a bit easier to apply overall. Less expensive than carbon veil, a bit heavier and not as stiff but works fine. We built all our stuff with glass and epoxy paint 20 years ago when 60's were king. The caveat with glass is the weave bleed through after a couple months when done very light, but it's a minor concern.
The major caveat with any light finish is the lack of resistance to hanger rash. I store my panels in the original husks which have been lined with felt cloth. Literally build a box around the husks which serves as carrier to the field. One set of panels is 6 years old and still looks like new. That set of panels was done is silkspan and dope
MattK
Update :
I saw today at Model Airplane store ( not so close to my home, but .. its possible to buy from them - a microglass ( 25 Gram ).
There is any diffrence between microglass and fiberglass ?
Just wanted to be sure by now
Thanks.
..Thanks.
