Harmony Bipe
Old 06-14-2012 | 05:55 AM
RC_Pattern_Flyer's Avatar
Default RE: Harmony Bipe
Jason,
The harmony has just completed it's makeover to electric!
After the initial flights..rebuilding wings...changing incedence etc
We are at 10 lbs 14 ounces with the following equipment:
Dualsky 6355 10
Pt models carbon 2012w
Rhino 4900 10s
Hobby wing 100 amp hv controller
450 mah receiver pack
Four aileron servos
Pull pull rudder
Deps elevator
Mark hunt has been making all the trimming adjustments and it grooves nicely now.
The harmony two has some great updates to it but unless you use very aggressive decisions in reducing weight it will be difficult.
Chuck
Ps : stay tuned this winter for a new project from area 51 here in texas
Old 06-14-2012 | 11:47 AM
Oooooh.....please tell more....
Old 06-14-2012 | 12:04 PM
More on harmony or new project?
Old 06-14-2012 | 01:03 PM
Jason Arnold's Avatar
Both actually...
Thanks for the update Chuck. The equipment you're using is not exactly the lightest so to still make weight is impressive. Are you able to advise on what the model's finish is i.e. film, paint etc?
Cheers,
Jason.
Old 06-14-2012 | 02:19 PM
Out of my list, I believe the "heavy parts" are the ESC, which is maybe one ounce heavy and the batts weigh 1240 grams fyi.
everything else is light, plane is covered totally in monokote.
i will try and get Mark to take some current pics of the plane.
Chuck
(not sure if the cat will be out totally on the project yet)
Old 06-14-2012 | 02:34 PM
  #31
In regards to my original Harmony.
Wings, well, mine were Foam core.. which I built in such a way that required me to add flying wires (carbon rods). The Harmony 2 has built up wings and avoids this problem.
For the Fuse, it is similar to the 2 and what i did with mine was:
1. I built the stabs and rudder as traditional open bay structures with sheeting to the high point and then cap strips.
2. I took the fuse sides and starting at the nose, I sheeted solid till the firewall.
Then from the firewall to the leading edge of the bottom wing, I routed out 1/3 of the sheeting thickness except where the sheeting touched formers
Then... from the leading edge of the wing to the last former behind the wing I routed out 2/3 of the sheeting thickness except where it touches formers.
THEN... from there back I removed all the sheeting ...except where it touched formers.
3. On the Harmony one, there was a lower foam turtledeck that i cut large lightning holes in once I sheeted and glued it to the fuse.
4. I cut or sanded or removed or replaced anything i felt was unecessary or overbuilt.
Chuck
Old 06-14-2012 | 03:57 PM
  #32
ORIGINAL: RC_Pattern_Flyer
Out of my list, I believe the ''heavy parts'' are the ESC, which is maybe one ounce heavy and the batts weigh 1240 grams fyi.
Chuck
Thanks Chuck,
Some current pictures would be nice.
PS. Time to let the cat out of the bag... lol
Cheers,
Jason.
Old 06-15-2012 | 05:18 AM
  #33
flyintexan's Avatar
Here are some pics of the nose area. The chin is removable via an MK magic box. The batteries are held in place with just velcro strip and a strap on lite ply right behind the motor. You can see the big (understatement) ESC just mounted to some of the lite ply structure. The motor is performing very nice and is front mounted with a rear bearing support. Currently running a 22x12wide making about 2600+watts.
ID:	1772214   Click image for larger version
ID:	1772215   Click image for larger version
ID:	1772216   Click image for larger version
ID:	1772217   Click image for larger version
ID:	1772218   Click image for larger version
ID:	1772219   Click image for larger version
Old 06-15-2012 | 05:22 AM
  #34
flyintexan's Avatar
Some in-flight pics.
ID:	1772221   Click image for larger version
ID:	1772222   Click image for larger version
Old 06-15-2012 | 08:20 AM
  #35
I really like the projects that come out of Area 51. Let's us know about the project when you can.
Old 06-15-2012 | 09:04 PM
  #36
OK, Fat cat outta the bag. Please, understand that the biggest surprises lie beneath the surface and what you see is only a solid works model of the initial concepts.
Old 06-15-2012 | 09:52 PM
  #37
Jesus Chuck! The fuse looks like a fish...
Looks like a very symetrical design.
Cheers,
Jason.
Old 06-16-2012 | 02:09 AM
  #38
Now that really is interesting!!! Is it all going to be built up? Please start a build thread when it becomes a reality.
Old 06-16-2012 | 05:57 AM
  #39
All built up, wing tubes top and bottom wing, adjusters for the wings to fine tune incedence, goal of no flying struts.
Considering a gear setup similiar to the Geebee r3.
Very Retro... definite build thread once we get going.
Jason, funny you should mention fish, the plane is called the Remora.
Chuck
Old 06-16-2012 | 06:51 AM
  #40
Here is the most recent project, really a frankenstein setup. I was wanting to try swept wings again, had a fuse that was originally for a bipe but got frustrated in how to mount the top wing...it sat for four years and so I mated the two projects.
Ala.... Sting Ray
It has one flight, faulty elevator extension on one half and had to abort testing.
Enjoy.
Chuck
ID:	1772549   Click image for larger version
ID:	1772550   Click image for larger version
ID:	1772551   Click image for larger version
Old 06-16-2012 | 01:32 PM
  #41
Chuck
Hi Chuck,
Well the first thing that popped into my mind was fish. Fully adjustable wings is an interesting concept. Keeping the weight in check will be the challenge.
Cheers,
Jason.
Old 01-19-2013 | 12:05 PM
  #42
Adding a few pics to bump the thread, please visit our facebook page for the project.
Facebook Page : InsightRC Remora
Chuck
ID:	1842183   Click image for larger version
Old 01-19-2013 | 02:14 PM
  #43
Hi Chuck,
Good to see the Remora out of the bag...
Cheers,
Jason.
Old 01-19-2013 | 07:37 PM
  #44
Mark,
I like the side profile, if anything, it is unique and original. I think that the symmetry of it is what makes it look right. Good luck with it.
Teo
Old 01-19-2013 | 08:23 PM
  #45
Bill Clark's Avatar
venturing outside of the status quo is very refreshing. looking forward to seeing this on come to fruition
Old 08-17-2018 | 04:21 PM
  #46
slamn sammy's Avatar
Default Harmony Pattering
I have one of Mike Harrison's Harmony Bipe's. Just wondering lf it's worth anything. Needs a little work. Knowing Mike, l've been trying to reach him with no luck. If anyone know whats it's worth, PM me on Face Book or Email me at [email protected] with a phone number & l'll retrun your call.
Old 08-30-2018 | 06:00 AM
  #47
this is Mike Harrison. That is the first Harmony Bipe I built. I gave it to Trent Young so you must have gotten it via Trent. It is basically a fun fli airplane now. it is too heavy for pattern. Trent was going to put a gasser in it.
have fun.
