SAP 180 (Syssa Performance)
#977
NY
ORIGINAL: RC11
Is there any chance that a bobbin style 8/32 vibration mount would do the trick? Google Anti vibration mount and see what you think..
RC
RC
The [link=http://www.rcuniverse.com/forum/m_6285026/anchors_6285026/mpage_1/key_/anchor/tm.htm#6285026]Hyde-style soft isolator mount[/link] is the best (only?) way to go, and they aren't all that hard to make once you undertand the process and [link=http://www.rcuniverse.com/forum/fb.asp?m=9692415]how the concept works[/link].
I was a bit dubious at first about how well the mount would work and about my ability to make one, but it turned out to be easier than I thought, and it is working fabulously well. I will be making another one in the next few months if I am able to find a second-hand plane to go with my #2 SAP-180.
#978
OH
I am glad that you said something. I have some on the bench ready to be mounted. Your comment makes absolute sense thou. The ring on the hyde style mount locks that sort of movement out. Dave Brown sells a similar style mounting system. It is mounted to the engine backplate and with out stand offs.
Thinking out load now...
If the motor was mounted to a ring similar to the your hyde mounts then the sandwich mount between and to the firewall that would eliminate the translational stresses that the motor standoffs would be subject to. Just a thought.
I know, "just make the hyde mount already"
ggeeesh.
Again thanks for saying something.
ggeeesh. Again thanks for saying something.
#980
NY
Wow! 22 lbs!! Perfect for a 3D setup - should yank a 12 lb plane out of a hover with no problem!
I measured my pattern combination with a simple spring scale (fish scale... not too accurate[&o]) and it pulls a bit under 15 lbs, but with much greater pitch speed (with the 15.5x12W) and much quieter.
#982
OH
Most of that is air frame noise. I have the same bird and the thing is loud. I am working on quieting a few things down. Most of that noise is from the ball links on those big barn doors of ailerons.
#983
ORIGINAL: tele1974
#984
NY
ORIGINAL: MTK
I have soft mounted the SAP 180 in the EFXtra as shown in the thread for that plane. I believe I posted a bunch of photos on that. Much quieter set-up. Expect 3-6 dB delta on noise
ORIGINAL: tele1974
Do you think the increased noise with the Extra is due to the more voluminous fuse and cowl (and wings, perhaps) and the open structure design? All else being equal - with the engine, mount and exhaust - what else could it be?
#985
ORIGINAL: cmoulder
But it is still louder than the Temptress (which is extremely quiet by gas standards!), no?
ORIGINAL: MTK
ORIGINAL: tele1974
Temptress is about as quiet with the SAP as with the Webra 160 after considerable work to get her there....not quite but very close. A fully enclosed tunnel with dead foam lining would quiet the set-up even more,,, but the same would be true of a glow set-up. What we are fighting is the considerable increase in exhaust temp compared to glow. Hot reports are louder than cooler reports.
If we want more quiet, we need to cool the pipe (exhaust gas) more effectively. That's not a trivial thing.....a much closer fitting shroud surrounding the pipe would help but adds weight. Can't really make it out of depron because it would eventually melt from the gasoline. Glass is heavy and so is carbon...and expensive. Soft balsa would help but also adds weight. Soft balsa shroud is probably the best bet.
On the other hand, I have a pretty quiet set-up already so I am not inclined to investigate much further. If something makes sense in the process of assembly then I will incorporate it.
The set-up shown in the video is very loud compared to pattern set-ups but that's a requirement for the type of flying it is intended for. It's a show plane....spectators are attracted to loud.
#986
I think the camera microphone made it sound horrible and loud....louder than in person by quite a bit.
Also, the exhaust is being thrown right down on the asphalt...so that probably does not help at all...
I have quite a bit of air going through the tunnel...should help. It sounds quiet in the air...much quieter than on the ground.
#987
NY
Todd,
I guess that was a rather unfair impression of the sound since the video was made directly behind the plane at full throttle!
Have you installed or do you plan to install smoke?
A simple crankcase pressure system with a couple of check valves would be extremely lightweight. I did this with a .46-sized Decathlon (with a .61, of course) and the total dry weight was 5 oz.
#989
OH
Got some air time in this morning. I only have a 18x6 and a 18x10 and I definitely preferred the 18x10 for my flying style. I am practicing to enter my first IMAC competition. I will need to go back and read your information about props.
Crazy power with the 18x6 thou... up lines... not a problem. Thats definitely the 3d prop.
With the 18x10 it wasn't pulling over the top well, up lines were weak.
Smoke?... I'm in.
Smoke?... I'm in.
#990
NY
I can't comment on the 3D props, but suffice to say that the IMAC precision flying sequences have a lot of similarities with pattern. With the Extra being a somewhat draggy airframe, perhaps an 18x8 or 17x10 for IMAC precision (??).
I was able to add another prop to the list I've tried - the APC 17x12N (narrow) pattern prop - and, as I have said about some other props, it isn't horrible but it in no way matches the brilliant performance of the 15.5x12W with my [link=http://www.rcuniverse.com/forum/fb.asp?m=9732410]SAP-180 cookbook[/link] set-up.
#992
If you haven't seen Todd's Extra fly... I posted these on the other thread... this may be redundant:
[youtube]http://www.youtube.com/watch?v=GZjNyixe0sw[/youtube]
[youtube]http://www.youtube.com/watch?v=FrokdPQ5kh4[/youtube]
#993
ORIGINAL: tsyssa
18x8 would probably be nice if the noise was reasonable.
Both props would be good sport and 3D props
#995
I've been to that flying site and it extremely nice. By far the best one I've been to since moving to the NE 5 years ago. I would love to hold a Pattern Contest there if the club would allow a weekend for the Pattern Fliers. Even a 1 day contest would work.
Last weekend we were at Coningham PA, which is a club that has no pattern fliers in their midst. Yet they held a Pattern Meet. Pattern contenstants generally run the administative work so the club only needs to provide helpers for the concessions stand and impound. Don't even need a Contest Director...many of us are CDs so it's no big deal. The entry fee was 35$ so the club coffers were padded with about 500$ plus the income from the concession stand. It's one way for a club to add some income
#996
OH
Ran the 18x10 some more today and 4-5 minutes into the my second flight I lost the top end. Landed and the motor had tightened up pretty bad and it didn't sound very good turning it over. Went back to the 18x6 after a long cooling period and it was certainly much happier with that prop. I have the 15.5 on order. What the heck happened... I am thinking I got it way too hot. It wasn't air flow.
#997
ORIGINAL: tele1974
Here's where I was when my engines were new[link=http://www.rcuniverse.com/forum/fb.asp?m=9536834]MattK's early needles[/link]
The needles now after pretty close to full break in are HS 2 1/8 open and LS 1 1/8. Pipe is at 28" to baflle straightline from the spark plug center. Running 90 octane at 50:1 BelRay MC-1 synthetic motorcycle oil. The prop is a 17x12 std blade but a variety of props will run at these settings. I tried the prop Bob Moulder lent me (15.5x 12W) and also Dave's 15.75 x 11, 3 blade. These all work okay on the set-up. The 18.1x10 apc is a good choice for break in and if you don't mind a little noise, will work very well on pattern planes.
The 18x10 should be less load than all of these props.
#999
ORIGINAL: tele1974
I should be just above 8000 with the Xoar 18x10 on a pipe. Is that correct?
8K is probably low based on the experiments with the 18.1x10 apc. Except it's much warmer and more humid than when we getting out numbers in early spring so 8K is possibly in line, but I don't know. I've not run that specific prop
#1000
NY
ORIGINAL: tele1974
This engine likes the revs! Find a prop that permits over 9000 rpm and you will be happy. Even for pattern, my engine is quite happy with the 15.5x12W turning 9200 rpm.
This is why I think you might end up with an 18x8 (at most! - maybe even a 17x8!!) for IMAC precision, or whatever prop Todd was using in the recent video that produced 22 lbs of thrust![sm=thumbup.gif][sm=thumbup.gif]
