CA MODEL ONAS BUILD
Old 04-20-2010 | 10:40 PM
Default CA MODEL ONAS BUILD
Hello!!
I will start a buid thread on my new Onas by CA Model.
First I have to say that the kit is amazing, they have realy improved their quality. everything is fist class. there is a big difference from the previous kits such as the Pass-Port, Osmose, genesis, wich I previously build.
the fuselage is vacum baged with balsa, realy strong and ligth. the outside surface is mirror like, near perfect finish.
wings and stabs are as always very ligth and exelent quality
The wing tubes are exelent
realy EXELENT work CA Models, this is realy an amazing kit.
here are the weigths of the components just out of the box.
-Fuselage: 636g
-Canopy: 88g
-Cowl: 71g
-Landing gear: 106g
-Wheel pants: 17g
-Rudder: 34g
-Stabs (both): 96g
-Wings (both): 400g
-wing tube: 79g
-Stab tube: 16g
This time I will make this one Electric... yes, I said electric.... I want to try this thing out. (no, I will not stop Flying YS), power will be a NEU F3A
so as this thing is going to be electric and I have never done it before if anyone wants to add something during the build please help me!!
some pictures...
ID:	1421914   Click image for larger version
ID:	1421915   Click image for larger version
ID:	1421916   Click image for larger version
ID:	1421917   Click image for larger version
ID:	1421918   Click image for larger version
ID:	1421919   Click image for larger version
ID:	1421920   Click image for larger version
ID:	1421922   Click image for larger version
Old 04-21-2010 | 06:45 AM
My Feedback: (46)
Default RE: CA MODEL ONAS BUILD
You really should move this to the electric pattern forum.
Old 04-21-2010 | 06:57 AM
Hi Tuny,
I am sure that I the end of the day you will fly the electric a lot more than the YS powered planes. I started to fly electric 3-4 years ago and kept my YS powered models. Last season I never flew the YS and finally decided to convert to 100% electric. It was slow process for me but it is happening for sure.
VB
Old 04-21-2010 | 08:50 PM
Hello Vince!!! well, let's see how this thing goes....
today I started by marking and cuting the ventilation holes in the fuse, as these holes may become usefull during the building for acces to some spaces.
then I started working on the landing gear, laminated the 2 pieces of 1/8 plywood with 30 min epoxy, then sanded the fuse to get a good woog grip, and then glued the landing gear mount with 3 hour epoxy and lots of microballoons.
pics.
ID:	1422440   Click image for larger version
ID:	1422441   Click image for larger version
ID:	1422442   Click image for larger version
ID:	1422443   Click image for larger version
ID:	1422444   Click image for larger version
ID:	1422445   Click image for larger version
ID:	1422446   Click image for larger version
ID:	1422448   Click image for larger version
ID:	1422449   Click image for larger version
ID:	1422450   Click image for larger version
Old 04-21-2010 | 08:54 PM
one more
Old 04-22-2010 | 10:23 PM
some little progress today.
glued the landing gear reinforcements, later marked and drilled the holes for the 3 mounting screws on each side (4-40) and then aligned the landing gear on the fuse and marked the holes.
ID:	1423123   Click image for larger version
ID:	1423124   Click image for larger version
ID:	1423125   Click image for larger version
ID:	1423126   Click image for larger version
ID:	1423127   Click image for larger version
Old 04-24-2010 | 08:42 PM
more....
ID:	1424274   Click image for larger version
ID:	1424275   Click image for larger version
ID:	1424276   Click image for larger version
ID:	1424277   Click image for larger version
ID:	1424278   Click image for larger version
ID:	1424279   Click image for larger version
ID:	1424280   Click image for larger version
ID:	1424282   Click image for larger version
ID:	1424283   Click image for larger version
ID:	1424284   Click image for larger version
Old 04-24-2010 | 09:03 PM
more....
ID:	1424305   Click image for larger version
ID:	1424306   Click image for larger version
ID:	1424307   Click image for larger version
ID:	1424308   Click image for larger version
ID:	1424309   Click image for larger version
ID:	1424310   Click image for larger version
ID:	1424311   Click image for larger version
ID:	1424313   Click image for larger version
ID:	1424314   Click image for larger version
ID:	1424315   Click image for larger version
Old 04-24-2010 | 09:05 PM
and more...
ID:	1424322   Click image for larger version
ID:	1424323   Click image for larger version
ID:	1424324   Click image for larger version
ID:	1424325   Click image for larger version
ID:	1424326   Click image for larger version
ID:	1424327   Click image for larger version
ID:	1424328   Click image for larger version
ID:	1424330   Click image for larger version
Old 04-24-2010 | 10:41 PM
Hello Tuny: does the fuse comes with the marks to locate the tube and sleeve?
thank you
Mvelez
Old 04-26-2010 | 10:02 PM
yes, the wing tube location is marked on the fuse.
today I finished the cowl instalation.
pictures.
ID:	1426020   Click image for larger version
ID:	1426021   Click image for larger version
ID:	1426022   Click image for larger version
ID:	1426023   Click image for larger version
ID:	1426024   Click image for larger version
ID:	1426025   Click image for larger version
ID:	1426026   Click image for larger version
ID:	1426028   Click image for larger version
Old 04-27-2010 | 10:25 PM
I started the motor instalation, I will use a Budd engeniering engine mount, and the prop adapter is electrify
now I have to figure out how to get this thing inside the fuse....
pics of engine so far.
ID:	1426738   Click image for larger version
ID:	1426739   Click image for larger version
ID:	1426740   Click image for larger version
Old 04-27-2010 | 10:59 PM
Tuny amigo:
Bien venido al mundo de los electricos congratulations nice job
Lalo
Old 04-28-2010 | 07:02 AM
Tuny,
You will find soon that it is a lot easier than installing a YS engine.
Saludos,
Vicente
Old 05-02-2010 | 08:36 PM
Ok! here is what I came up with to mount the motor...
made a former out of 1/8 lite-ply then laminated on both sides with carbon, that made the front support
in the back I made a support ring from 1mm carbon and a fuel tube, that goes with 4-40 screws to 1/8 ply formers on both sides.
pics...
ID:	1429854   Click image for larger version
ID:	1429855   Click image for larger version
ID:	1429856   Click image for larger version
ID:	1429857   Click image for larger version
ID:	1429858   Click image for larger version
ID:	1429859   Click image for larger version
ID:	1429860   Click image for larger version
ID:	1429862   Click image for larger version
ID:	1429863   Click image for larger version
ID:	1429864   Click image for larger version
Old 05-02-2010 | 08:39 PM
more...
ID:	1429867   Click image for larger version
ID:	1429868   Click image for larger version
ID:	1429869   Click image for larger version
ID:	1429870   Click image for larger version
ID:	1429871   Click image for larger version
ID:	1429872   Click image for larger version
ID:	1429873   Click image for larger version
ID:	1429875   Click image for larger version
Old 05-02-2010 | 09:02 PM
Gracias Lalo!!! veamos como sale esto de los electricos.... (pero sigo volando YS)
Slaudos!!!
TUNY
Old 05-03-2010 | 10:13 PM
started the fuel tank tray... ooops sorry, the battery tray...
I made it from 1/8 balsa and 3/4 oz fiberglass on both sides, then I will add two 4mm carbon rods on the bottom side as reinforcements.
pics.
ID:	1430386   Click image for larger version
ID:	1430387   Click image for larger version
ID:	1430388   Click image for larger version
ID:	1430389   Click image for larger version
ID:	1430390   Click image for larger version
ID:	1430391   Click image for larger version
Old 05-05-2010 | 10:23 PM
battery tray done, then glued the former that will support the front end to the fuse, then open the floor to loose some weigth and alow more air flow.
pics.
ID:	1431487   Click image for larger version
ID:	1431488   Click image for larger version
ID:	1431489   Click image for larger version
ID:	1431490   Click image for larger version
ID:	1431491   Click image for larger version
ID:	1431492   Click image for larger version
ID:	1431493   Click image for larger version
ID:	1431495   Click image for larger version
ID:	1431496   Click image for larger version
ID:	1431497   Click image for larger version
Old 05-05-2010 | 10:25 PM
one more pic
Old 05-09-2010 | 01:05 AM
Next before finishing the battery tray, I took advantage of the big hole in the bottom as it provides nice acces to building the canopy.
the canopy holds in place with six carbon pins and one 4-40 screw. a quick release system is also nice, but I'm happier this way.
pics...
ID:	1433193   Click image for larger version
ID:	1433194   Click image for larger version
ID:	1433195   Click image for larger version
ID:	1433196   Click image for larger version
ID:	1433197   Click image for larger version
ID:	1433198   Click image for larger version
ID:	1433199   Click image for larger version
ID:	1433201   Click image for larger version
ID:	1433202   Click image for larger version
ID:	1433203   Click image for larger version
Old 05-09-2010 | 01:06 AM
more...
ID:	1433205   Click image for larger version
ID:	1433206   Click image for larger version
Old 05-10-2010 | 11:00 PM
more on the battery tray.
the rear support will act as rear support and landing gear reinforcements, as it distributes the loads from the landing gear mount through the fuse better.
then there is a middle support for the tray, this will make enougth for a solid mount that will hold the loads of the heavy battery. (that structure has to support a 1.3 kg battery plus the G forces during fligtht), I made the battery tray long enougth so I have a lot of room to play with the CG
pics.
ID:	1434198   Click image for larger version
ID:	1434199   Click image for larger version
ID:	1434200   Click image for larger version
ID:	1434201   Click image for larger version
ID:	1434202   Click image for larger version
ID:	1434203   Click image for larger version
ID:	1434204   Click image for larger version
Old 05-11-2010 | 09:59 PM
battery tray done.
pics.
ID:	1434666   Click image for larger version
ID:	1434667   Click image for larger version
ID:	1434668   Click image for larger version
Old 05-12-2010 | 06:26 AM
Tuny,
Very nice and clean work. Thanks for sharing.
Vicente
