RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Temptation Kit (https://www.rcuniverse.com/forum/rc-pattern-flying-101/1935288-temptation-kit.html)
tph1 02-10-2005 07:56 PM
RE: Temptation Kit
It will be at Ocala unless something unforseen happens. And on the colors, there are a lot of planes red yellow white and blue I just changed the blue to green to be different.
MHester 02-10-2005 08:33 PM
RE: Temptation Kit
I'm fairly bored of red/white/blue/yellow myself. Look down the flight line at any contest, you'll see what I mean.
I like mine to stand out a bit.
-Mike
Rune 02-11-2005 12:29 PM
RE: Temptation Kit
hi .
looking good Tom!
your close to test flight!
i belive i have almost a month left!
Rune
tph1 02-12-2005 02:15 PM
RE: Temptation Kit
1 Attachment(s)
I couldn't resist. I took a couple more pics after I covered the other wing this morning. I'm going to try to have it all rigged and ready for next weekend. The flying field should be deserted while they run the 500 next week.
Rune 02-12-2005 03:33 PM
RE: Temptation Kit
nice Tom!
haveu chose to not use the original undercarriage?
good luck on the test flight ..its always exeting to make a test flight!
Rune
mups53 02-12-2005 03:47 PM
RE: Temptation Kit
Looking good Tom. Wght engine are you putting into the plane? I have had 2 Temptations but my first one died a horrible death. I miss it. Mike
tph1 02-12-2005 04:30 PM
RE: Temptation Kit
I didn't get any gear with it Rune, I bought it second hand so I'm using Bolly. The test flight will be a nerve racking time, but it has 4 Gator adjusters on the wings so I should be able to get it pretty close to right though. As far as the motor Mike, it is a 140L with NMP header and Hatori pipe.
Rune 03-24-2005 12:05 PM
RE: Temptation Kit
1 Attachment(s)
hi!
so then the Temptation is ready for engine and radio equipment!
is any other finished and have flown it ... the field are not in a good shape yet the snow is melting and its very wet ..maybe some time after easter!
Rune 04-09-2005 07:41 AM
RE: Temptation Kit
1 Attachment(s)
finally tomorrow if weather is nice its time for test flight!
ended up at 4530 gr ..don't know what that is in lb's but it should gives plenty off power !
took 2 more pics with a better camera all that missing now is some decals that are ordered but not finished yet !
Os engine ,greve pipe ,self made hydemount (ola type) and semi alu \ steel header,apc 17x13 (thinking about 18x12) truturn Fai spinner , futaba digs on all except on throttle where a small hiteck is placed , carbone wingtube, oracover on wings and stabs+rudder and acrylic panit on fuse , but it seems that i have to move the CG back almost 15 mm but i test flight it first and see what i think!
Eric.Henderson 04-16-2005 10:25 PM
RE: Temptation Kit
Found, one unused temptation kit if anyone is still looking for one.
Eric.
MarkGrabowski 04-16-2005 11:04 PM
RE: Temptation Kit
Eric, p.m. sent....
Eric.Henderson 05-21-2005 06:07 PM
RE: Temptation Kit
I have been trying to open the Piedmont site with no success. Is anyone else having this problem?
If it is working could you post the URL on this thread and I'll see if it is my system that is blocking my access.
Regards,
Eric.
iflyrctoo 05-21-2005 07:03 PM
RE: Temptation Kit
Eric,
It opens for me.
http://piedmontmodels.com/
Joe
orland 05-21-2005 07:20 PM
RE: Temptation Kit
I am interested in a temptation kit > How much do you want for it>
Orland Mckee
Eric.Henderson 05-21-2005 11:55 PM
RE: Temptation Kit
I clicked on yours below, Same result - Must be my end. It says it cannot open the site! Thanks Joe.
ORIGINAL: iflyrctoo
Eric,
It opens for me.
Joe
Eric.Henderson 05-21-2005 11:57 PM
RE: Temptation Kit
It wasn't mine and it's gone already - sorry, Eric.
ORIGINAL: orland
Orland Mckee
