RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Widebody 60 question (https://www.rcuniverse.com/forum/rc-pattern-flying-101/2586426-widebody-60-question.html)
tph1 01-26-2005 01:16 PM
Is there enough room to get a YS 110 in the Widebody 60? With a Hyde mount?
thanks
tommy s 01-26-2005 01:22 PM
RE: Widebody 60 question
Yes
tommy s
tph1 01-26-2005 01:28 PM
thanks Tommy
tommy s 01-26-2005 01:42 PM
Tom,
If you haven't flown one yet they fly great. I've got one I need to finish that I
originally planned on putting a YS 1.10 with a Hyde mount in but the 1.10 is now
going in my 2nd Excelleron so it looks like the Widebody will get a MVVS .91 also
with a Hyde mount (same bolt spacing as the YS). You're going to like it.
tommy s
robert 01-26-2005 04:18 PM
I have a 110 in mine and it fits in ok, but I'm using a more standard mount. I glued blocks infront of the bulkhead for the cowl to screw into, that gave me a little extra space to put it in. Its a very good combo though, very powerful motor. Mine came in slightly above 7.5 pounds and could be built lighter.
tph1 01-26-2005 04:43 PM
that sounds great, will start on one soon
flyintexan 01-26-2005 11:46 PM
rwlewis had a wb60 w/ the YS110 and hyde mount...sport muffler just outside the cowl....
man, I miss that plane....and it wasn't even mine!
MHester 01-26-2005 11:59 PM
1 Attachment(s)
I miss mine too! It was the best flying 60-90 sized pattern plane I have ever flown, in my book it had no equal. I don't know about the infinity, leo or excelleron, but the WB 60 was hands down the closest thing I've ever flown to a 2 meter plane without being a 2 meter plane!
Stupid power line. May she rest in pieces...
-Mike
Panther45 01-28-2005 05:04 AM
yep yep
Mine has 25 flights and I can't imagine flight without it. Mine is 7.1 lbs with a 91 FX and it is a real fighting machine. When you find yourself thinking about ordering another one just in case, then you must like it.
tph1 01-29-2005 05:42 PM
What size spinner and MK bellcrank does it take?
blw 01-29-2005 10:02 PM
tph1,
I'm almost finished with a WB 40. I used the small MKD bellcrank. Having seen the WB 60, I would guess the larger one for it. I think there are only 2 sizes.
The MKDs are heavy and expensive. Does anyone know of a better company or a place that has them at decent prices?
robert 01-30-2005 07:11 AM
I fitted the smaller Mk driver and it just about fit so the bigger one would be better. I didn't get enough throw though for 3D flying so I used two mini servos in the tail instead.
tph1 01-30-2005 07:14 AM
How much torque did the mini's have Robert? What size spinner did you use?
thanks
leviva 01-30-2005 08:45 AM
I'm just got my kit to the covering stage but the spinner I used is 2 1/4 inch and it's a perfect fit with the cowl
robert 01-30-2005 10:21 AM
I'm using 3102's on each elev. So far they are holding up fine but I have yet to really push them. Jr 3421's (I think thats their number) would also be good choices.
tph1 01-30-2005 10:23 AM
OK thanks, what size spinner did you use, 2.25"?
thanks
robert 01-30-2005 10:25 AM
I don't have a spinner but I think its 2.5
tph1 01-30-2005 10:43 AM
OK thanks
robert 01-30-2005 12:39 PM
Nope 2.25 like all the others said. Sorry bout that. [:@]
blw 01-30-2005 09:59 PM
Robert,
What limited your MKD bellcrank throws? From the installation (and not hooked up yet) it appears that I can get more than 45 degrees up and down. Mine is about 1/3 the fuselage distance from the tail.
tph1 01-31-2005 04:48 AM
Does the 60 size take the bigger belcrank?
MHester 01-31-2005 10:25 AM
Yes the 60 size takes the large size bellcrank. It fits like a glove , it will be slightly forward of the stab LE a couple of inches. Works like a charm.
-Mike
tph1 01-31-2005 10:28 AM
Cool, I'll order one today, I have to call Central anyway.
tph1 01-31-2005 06:56 PM
Robert, What mount did you use? Is it a "Hyde" type?
Tom
lems 02-01-2005 08:19 PM
Tom, I lost your email and have a question to ask you. Please email me at [email protected] Thanks, Lem
