Adding satalites to DX8 receiver
I have a brand new DX8 radio system that I am going to install in a 1/3 scale Cub..I have been told that it is better to have extra satalite recievers and extra fail safe battery packs..I dont know how to add these or if it is even possible..I see there is a JR reciever with 3 satalites and wonder if this is compatible with the Spektrum system...Can any body tell me where to look or what to do? Thank you
RE: Adding satalites to DX8 receiver
Of courset all the Spekrtum receivers will work with the DX8. The 9000 series receivers have two satallites. You can also use the Jr receivers. They have a 9 channel and a 12 channel receiver that have two satellites. The Spektrum 8000 only takes one satellite and will work well in your plane.
I believe the fail safe battery set up you talk about are two batteries with a switch on each battery plugged into a receiver.
Banned
ORIGINAL: Hoosier06
So the two batteries would be on board the aircraft.
If a fail safe occur the switches are useless with the aircraft in flight.
I am trying to understand what you wrote.
Zor
ORIGINAL: bikerbc
http://www.spektrumrc.com/Products/D...odID=SPMAR9100
You can hook up Rx batteries to the Batt/Bind port, the Data port, or any Servo port on any receiver. Many pilots with expensive aircraft use Redundant battery packs whether it is 72Mhz or 2.4Ghz Rx's. When I need to, I plug one Rx battery into the Batt/Bind port and if all the Servo ports are used, I unplug a servo, plug in a Y Harness to the Servo port, connect the Servo to one side and the battery to the other. I have never used the Powersafe Rx, but many do.
You need to set up each Rx battery on a separate Switch Harness and charge each separately. This is very common.
Banned
All readers,
From reading Rich (BushBarber) the two batteries are connected to the receiver at the same time and the switches are used on the ground to charge the batteries individually without taking them out of the aircraft.
It makes me wonder why they are referred to as "fail safe batteries".
In flight they are simply in parallel and if a fail safe do occur there would be no difference from a single battery having twice the capacity assuming they are both rated the same mAh.
Somehow some clarification will come out of this discussion.
Zor
Zor
ORIGINAL: Zor
All readers,
It makes me wonder why they are referred to as ''fail safe batteries''.
Zor
All readers,
Zor
These are no Failsafe batteries, but rather Redundant batteries. If one battery quits, the other battery still powers the Rx. If both batteries quit, you crash. If you have a Brownout, you do not go into Failsafe, but you have not control until the Rx reboots. Also with Redundant batteries, you have two Switch Harnesses, so if the batteries are OK, but one of the Switch Harnesses shorts out or breaks, you still have power from the Redundant battery.
Thanks BuschBarber, I believe you have me on the rite track. I think the AR9100 is what I was looking for , Also thanks for taking the time to explain how this all works...Ken
ORIGINAL: bikerbc
Banned
[quote]ORIGINAL: BuschBarber
[quote]ORIGINAL: Zor
All readers,
Zor
BuschBarber,
Red inserts by Zor
Failsafe occurs when the Rx loses the signal from the Tx, either by Interference, or by loss of Tx power.
Or due to nearly out of phase reflections or receiver antenna orientation. The fails safe occur due to a weak signal at the receiver antenna. The transmitter signal can be normal while the receiver antenna does not pick up sufficiently.
The Rx has to be powered in order to switch to Failsafe mode.
Of course.
Not necessarily so. If one battery shorts or comes to have a very low voltage it will affect the other battery. The resulting voltage may become insufficient to power the receiving system and the servos or ESC properly. If one battery simply opens (as if it was disconnected) then no problem would occur.
Ah ___come on ___ if a switch shorts out we then have a closed switch which would be normal.
You would still have power from both batteries.
Red inserts by Zor
Of course.
Zor
Most Switch Harnesses will Fail Open. Only more expensive ones are designed to keep the circuit closed when the Switch fails. Most people do not have these more expensive Switch Harnesses, which is one common cause of crashes that are commonly blamed on Rx failure.
ORIGINAL: flyallday
BuschBarber, what about using a BEC, like a CC 20 amp Pro and a back up battery? Is that possible?
Harry
Harry
CA
I am using the CC Pro on 3 of my large electrics as well but power them with the flight pack. My largest is 80" so I am ok with the current set up but was thinking about going larger and would most likely want some back up power. I like the way you do it with a separate lipo, but could you also include another battery for redundancy?
Harry
Harry
ORIGINAL: flyallday
I am using the CC Pro on 3 of my large electrics as well but power them with the flight pack. My largest is 80'' so I am ok with the current set up but was thinking about going larger and would most likely want some back up power. I like the way you do it with a separate lipo, but could you also include another battery for redundancy?
Harry
Harry
http://www.rcuniverse.com/magazine/a...rticle_id=1330
You can connect more than one battery to your Rx. You certainly use a voltage regulator of the same type (or BEC) with each battery.
CA
Thanks Rich, I started reading the article and realized that I had already seen it! Great article, some of the vids from the motor testing are almost funny. Just waiting for that rig to take off.. Again, thanks for the reply.
Harry
Harry
ORIGINAL: flyallday
Harry
Harry
ORIGINAL: Zor
Hello Hoosier06,
Zor
ORIGINAL: Hoosier06
Zor
My Feedback: (41)
ORIGINAL: bikerbc
Now here's a bit of information that's caught more than one of us on setup; the manual says you can use only two satellites but that is incorrect. It MUST have at least three satellites connected to work and no I won't mention how I and others found that out.... lol
ORIGINAL: bikerbc
We have one of these units in our 56CC UAV and the way I understand it.... if one battery fails it switches to the other battery..... so one bad battery wont drag down the good battery...
http://www.smart-fly.com/Products/Expander/expander.htm
My Feedback: (14)
I would be careful with the DX8. Even though it is stated as DSM2, it apparently is DSMX, and the reciever has DSMX satellites even though they are DSM2 labeled. It would be wrong to mix satellites DSM2 and DSMX with each other. Presently there is some confusion as to what is really DSMX with the recievers, and satellites, with their labeling. Even though they are labelled DSM2 if there is a X in small print on the back of the satellite then its DSMX. Dont get them mixed, apparently that would not be good. Apparently, the telemetry modules have been DSMX, all along, even though labelled DSM2. Not so critical here however.
Banned
ORIGINAL: indubitably
I understood from previous postings by others that DSMX transmitters work correctly with DSM2 receivers and DSM2 transmitters work correctly with DSMX receivers.
Zor
Banned
ORIGINAL: BarracudaHockey
Thats correct they do, but you cant add DSM2 satalites to a DSMX receiver and vice versa
Zor
