Polk Seeker II rcvr - single conversion?
CA
Just received my Polk Seeker II. Works as advertised on the bench, and I haven't read anything bad about them, so I'm going to give it a try.
Saw in the literature from Polk that this is a "narrow band" receiver (which is a good thing), but doesn't say anything about dual conversion. I thought single conversion was for park flyer receivers.
If it is single conversion, is this a concern? Or does the Seeker technology not need "dual conversion"?
doug
doug
CA
The cheap $30 park flyer Rx's have given SC a bad name. Please see these docs:
http://www.bergent.net/SC-DC.pdf
https://www.fmadirect.com/support_docs/item_1075.pdf
UT
The seeker is neither single nor dual conversion. It utilizes PLL (Phase-Locked-Loop) technology to lock onto the frequency much the same way a digital radio tunes into a station.
<Correction> I just learned the Seeker DOES employ dual conversion.
quoted from http://www.its.bldrdoc.gov/fs-1037/dir-027/_3944.htm
phase-locked loop (PLL): An electronic circuit that controls an oscillator so that it maintains a constant phase angle relative to a reference signal. (188) Note: Phase-locked loops are widely used in space communications for coherent carrier tracking and threshold extension, bit synchronization, and symbol synchronization.
NY
PLL's don't have anything to do with weather or not a receiver is dual or single conversion. PLL's just replace the crystal for frequency stability. Dual/Single is because the parts required to deal with an RF signal at it's native frequency are so expensive due to them having to have very high tolerances. If the native frequency is down converted to a lower frequency cheaper parts can be used. If you use extremely high quality temperature and voltage compensated parts/circuits you don't need to convert the signal at all. But in the real world at high frequencies this is just not practical. The reason single conversion receivers are usually used in park fliers is because the circuit (hence the size and weight) for them is lower. They're also usually lower ranged, but a high quality single conversion is just as good as a dual conversion. The quality and tolerances of the parts used to make it up are more important than the technology that drives it in a lot of cases.
UT
<Edit> I just noticed Doug asked Mr. Polk in the manufacturer's support. Here is his reply:
It's definitely dual conversion. As a matter of fact our engineer invented low cost dual conversion when we wer's d having our product made by Hitech. We know how important this feature is and wouldn't make anything that wasn't dual conversion.
NY
I have no experiance with them personally but so far from all the posts here I've read and all the information on their site they have top notch products. After the seeker has been around for a while I'll more than probably pick one up. No crystals is a nice thing.
CA
Sorry guys, still getting used to posting on here. I should have come back to this thread and mentioned both that I had posted to the mfg's forum (which I found after posting here) and that I had recieved an answer from Mr. Polk.
I also want to point out that I had my answer from Mr. Polk within hours after posting my question - great response.
doug
doug
UT
I have to agree with Doug - Polk's Hobbies service is top notch. They are very helpful on the phone, and Mr. Polk is usually very propmt at replying to emails and questions posted in the manufacturer forum.
