Eclipse setup Question?
Just ordered an eclipse radio for a Cap 232 that I am building and am curious about set up . It is a scratch build with flaps, ailerons, and have tamed it down somewhat. I.E 1200 sq. in. 74" span . Would like to have the ability to control flaps as ailerons, also can I run two elevator servos with this radio. Was looking for info on various radio setups but no luck there .
Any help greatly appreciated.
Aloha, Les
Aloha, Les
CA
As for flaperons, there are menu choices for this in the manual on page 26.
CA
There should be no problem with using a "Y" cable to operate two identical servos to control the elevators.
-David C.
CA
You just flip the flip the arm over... That CAP's probably already set up that way.
A common mistake that can cause mysterious snaps
-David C.
