Hitec Eclipse VS Futaba 8U
My Feedback: (8)
CT
I'm getting a Hanger 9 Ultra Stick and I'm going to use the crow feature. I was going to buy the Hitec but found out that you can only use the crow feature in glider mode but after reading the manual for the Ultra Stick I find out that you can only use the crow in the Futaba in glider mode also. What's the difference? Sounds like I can use the Hitec after all or am I overlooking something?
Unfortunately the Eclipse cannot perform the crow feature that makes the Ultra Stik family so fun. If Hitec had a radio that could do this, then I would have divorced myself from Futaba quite some time ago. It is not that I don't like what Futaba has to offer, it is their prices are much higher than the prices for similar Hitec products.
You will need to get either the Futaba 8U/9C or get a JR 8103 or higher to use all the features of the Ultra Stik.
And trust us when we say it isn't possible. I had the techs on the phone about this a few times at Hitec. It is a no go with the LS .40. The Futaba is a great radio. I love it. You can get a used one with some goodies for around $250 used. Best money you will spend.
CROW -w- Futaba 8AU Yes for ACRO
The Hitec, on the other hand, cannot be set up for CROW outside of their GLID4 mode. Unfortunately, Hitec's GLID4 mode assumes the throttle does not exist and assigns the throttle stick to the CROW. You can't change this, therefore, you have no CROW with a powered airplane.
Re: CROW -w- Futaba 8AU Yes for ACRO
Originally posted by hilleja
...One possilbe limitation is it is difficult to setup full-span airlons.
