Upgrade servo?
TN
Upgrade servo?
I ahve two car a tc3 and a 4-tech and i am going to buy a new radio, but when you get a high-end radio such as the airtronics mx-3s or the Jr XS3 should you update the servo to. If i put the servo i get in the tc3 and buy another receiver to put in the 4-tech do I also have to upgrade the servo or can it handle the power of this kind of radio?
RE: Upgrade servo?
The signal to the servo from the receiver doesn't change when you use a higher priced transmitter. Or even a higher priced receiver for that matter. Assuming your old servos are normal servos that work the same as everyone elses and don't have some odd signal or wiring scheme, there's no need to upgrade them just because you changed transmitter and/or receiver.
That's not to say going to a better quality servo than what you have isn't with out benifits, it's just probibly not required.
