9C Spoileron setup?
VA
RE: 9C Spoileron setup?
Just started tinkering withthat myself. If you select acro-Flaperon mixing and assign Channel 6 to a knob or slider you get both spoileron and flaperon operation.
I've only played with this a little in flight on a GP Big STik and haven't incorporated any elevator mixing yet....
Mark
Mark
ND
same as exeter, i put that on the left slider, while engine 'trim' is on the right slider. works great, and on my ucand3d that is almost used so much I consider it a primary flight control!
