switches for radio ?
CA
RE: switches for radio ?
on off switches for the plane, switches on the transmitter? You can call futaba usa on it. Otherwise any switch with the same configuration will do. I've replaced a couple on my 6XA, took the switch out, mozie on down to the electronics shop and found one I liked. Course the warrenty is now voided since I opened the box
http://dkc3.digikey.com/PDF/T051/1155-1158.pdf this is digikey's catalog page for C&K switches. any type of actuator or solder connection you want and very high quality. best to choose a type with an anti-rotation pin in the lever. they also sell dress nuts for a few cents but your's will most likely fit anyways.
dave
dave
