Need Stronger Transmitter Stick Springs
LA
Springs
I tried adjusting the stock springs and still not enough. Drove to Pensacola, Fla., and waited while the guys at Radio South installed custom stiffer springs in my 8UAPS and 5 other Txs I brought for other local guys. Send them your Tx and you will be happy and its not much money. I think it was about $20 per Tx....Lenny
My Feedback: (13)
MN
John Buckner
I have adjusted the stock springs as tight as they go. They still aren't tight enough to prevent me from accidentally getting some unwanted aileron movement. The aileron springs are the only ones I need to replace.
Greg
Greg
Gentlemen,
You can buy the stiffer gimbal springs from Tower Hobbies for only $1.09.
http://www2.towerhobbies.com/cgi-bin...P?Q=1&I=LXAEM7
Hope this helps.
Don
Hope this helps.
Don
My Feedback: (13)
MN
Thanks for the heads up, BUT:
Tower wants you to back order 9 sets minimum. That would be 27 springs. Plus s/h.
I need someone that has them in stock.
Greg
Greg
www.radiosouthrc.com
They have the stiffest springs, Futaba heavy springs are little better than stock but not as strong as the Radio South ones.
You can order any qnty you want from Radio South.
Greg,
I ran into this same problem when I tried to order a 9C DSC cable from Tower that was out-of-stock. To place the order, I would have had to buy 3 DSC cables :-(
"Order Pending" means Tower is waiting for a shipment to arrive. When Tower has those springs back in-stock, you will not be forced in having to buy 9 sets of gimbal springs. I don't like this new Tower policy or way of doing business as it can be confusing and frustrating for some customers, including myself, and I don't think it's right. Those gimbal springs are a regularly stocked item ...and therefore the customer shouldn't be penalized by having to buy 9 sets of gimbal springs just because they are currently out-of-stock.
If you or anyone else feel the same way, voice your opinion and maybe AnnMarie will do something about it. I've personally seen her make changes/improvements before, but that was done on another forum (runryder.com), and people really had to come on strong.
Don
Don
Greg
Greg
