Changing frequency
My Feedback: (7)
RE: Changing frequency
Del,
What they sent you has nothing to do with your question. In the regs there is the statement that a certificate is not required to service radios in the radio control service.
Used to you had to be FCC certified to service R/C stuff, but no more. The regs say you must be qualified but do not say how to be qualified. I hold the GROL which used to qualify me but that is not needed anymore for R/C. I can still use it for avionics.
My Feedback: (7)
This is quoted from the November 2005 issue of the magazine R/C Report. Tony Stillman's article on page 83.
"Exactly what do service centers do during checkups? Usually it begins by testing the transmitter to be sure it's on frequency and that it's narrow band. This is done using a spectrum analyzer. If problems are found, the RF circuit is adjusted to meet current specifications. If the problem is an off-frequency issue, it may require that the crystal be replaced. This is not an unusual occurrence, although, we do see this type of problem from time to time.
Once the frequency is checked, the RF output power must be tested to insure an adequate signal is being transmitted. This can show itself in a range-check, but many times the RF output of a transmitter is not peaked from the factory. This is due to the way that the radios are manufactured now. The units are tuned using a factory standard crystal after which they replace the crystal with whatever frequency they're building that day. Tuning the system in this manner results in plenty of power in most cases, but the individual transmitter is not tuned with the crystal that's in it when we buy it. When this radio reaches a service center, we very often find that we can improve the output power by 10-25%. This is quite a difference. but not generally enough to cause a crash. Still, it's nice to know that your radio has been tuned for its full power output."
The color emphasis was added by me. Make up your own mind as to changing crystals.
TX
ORIGINAL: deli_conker
Just so everyone knows, it's obvious that you just pull out the crystal and replace it. I was wondering if that was all that had to be done. I had heard somewhere that you're not allowed to change out the Tx crystal because the Tx then needs to be tuned to the new frequency.
I have an Airtronics Vangaurd transmitter that I bought on chan 22. I bought a chan 21 trans crystal and have been flying with that transmitter for years on 21, no probs and no interference caused to those around me. Not sure I'd try it for a 5 channel change tho. That's probably far enough off that the transmitter ought to be retuned. I'd be alittle worried about it splattering enough to cause adjacent channel interference. I'd send it in to the mfr. They usually turn them around quickly.
CR
That looks like a general overview of license requirements. Nothing there about R/C. The FCC got rid of a bunch of license requirments years ago, the only ones left that require repair are a Commercial Radio license, Broadcast, Cable, International, and Amatur (not sure the license is required for repair though). Non of those cover R/C. If you read the reg close it says nothing about a license, only that the repair person be certified.
Forgot Maritime, no that doesn't R/C either, not even the boats.
#31
The pull out modular thing contains the crystal. When the transmitter was built, it was glued in with a tiny drop of glue to make it 'inaccessible' to the end user in the US.
#32
I do not know the licensing requirements to be able to swap Tx crystals. I'd guess the FCC web site has the info buried somewhere.
And before you say the warning negates that, the warning is about transmitting without a license, not repair. Check out the other license if you will, there is nothing for R/C
#33
NE
Sport, this thread is 3years old. Why bring it back? If you would have bothered following the link in this thread, where I posted 3 years ago that this stuff is spelled out VERY CLEARLY in part 95.221, you wouldn’t need to post three times in a row in a 3 year old thread.
http://edocket.access.gpo.gov/cfr_20...7cfr95.221.pdf
#34
TX
ORIGINAL: JohnW
So what's your point?
CR
#36
I posted this because it came up on the beginner forum. That reg you quoted is clear as mud. Anyone who has taken an electronic course can say he is qualified. There is no FCC license for the private land moble services as those license were done away years ago, the link I posted proved that. I thought since I found that site I would bring it up again.
#37
Changing the crystal is modifying the frequency determining components.
#39
The crystal is not the sole frequency determining component in the RF Circuit. There are several other components in the circuit so you are in fact making a modification to the Frequency Determinig Circuit by changing the crystal. Your lack of this knowledge demonstrates that you do not have the skills, let alone the equipment to be changing crystals and retuning the Frequency Determining Circuit.
#40
#41
I think the point is that you need the equipment and know how to ensure the transmitter is on frequency and within specs when you're done with it.
#42
IN
"IMO its not a modification unless it is transmitting on the wrong frequency"
Well If You bought a "CHANNEL20" transmitter,and changed the crystal in it to repair it. I assume that the crystal is being replaced to "repair" it,Because You have stated that it IS NOT a modification. IF it then transmits on any frequency other than channel 20,it is transmitting "ON THE WRONG FREQUENCY".
You MODIFIED it,and the act was "Against FCC regulations".They are NOT laws,only regulations.AND if caught,You WON"T be taken to court.You will be fined by the FCC themselves.It's like fighting the IRS,but Worse!
#43
#44
There's commercial users sandwhiched between our channels. This is why the restriction only exists on 72mhz and doesn't effect the ham or car guys.
They pay for the use of the band, we, on the other hand, are freeloaders.
Interfere with the paying users, and I can promise you, they will find you and fine you. It's 10 grand per occurance. Versus 30 dollars to get your radio tuned properly. This is also a chance to get it checked out and peaked.
The fact that you know something about the process is great. The average user shouldn't be messing with it.
#45
NE
Sport, I don't see how you could have read the reg I posted based on what you have posted. It very clearly says you must certified by an organization or committee representative of users in those services to adjust the TX. The organization or committee does the certification.
Again, like I posted in the other thread in beginners, I mean no disrespect, but the problem is not the FCC regs, but your misinterpretation and lack of full understanding on how the regs work. There is nothing broke in the regs here… don’t fiddle with the TX xtal… I think most can understand that.
#46
ORIGINAL: Sport_Pilot
I have never ever seen any glue on a TX crystal, it's BS. I have pulled them out to be double sure that the trainer radio is not trasmitting. No glue ever. Sombody came up with this BS to pretend they know what they are talking about.
Both of my Futaba 6XAS transmitters had a tiny drop of what looks like hot glue holding the crystal cap to the transmitter case. It popped loose with very little effort but that does not change the fact that it was glued in.
I couldn't get a great picture from less than a foot away but the glue drop is there.
But, I guess I'm just pretending to know what I'm writing.
#47
Sport, my knowledge is certified by the FCC with my General License, K4HLH, now tell me what is your certification. And I'll tell you again, the crystal is not the sole determining factor of the Frequency Determination Circuit.l
#48
IN
#49
#50
http://wireless.fcc.gov/commoperators/pg.html
