Why is this reciever so cheap?
Old 07-09-2006, 03:23 AM
cowana
Default Why is this reciever so cheap?
[link=http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=003&item=130001324505&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1]www.ebay.co.uk/ebayISAPI.dll?[/link]
I have bought it, and I want to use it with a 6EXA transmitter that I have not yet bought. Will it work?
Old 07-09-2006, 08:33 AM
exeter_acres
exeter_acres's Avatar
Default RE: Why is this reciever so cheap?
is it positive shift or negative?
there are certain areas where I refuse to cut corners... serovs and Rx's are at the top of that list
Old 07-09-2006, 08:35 AM
cowana
positive shift
Old 07-09-2006, 08:46 AM
exeter_acres
then it won't work....
Futaba uses negative shift, JR uses positive
Old 07-09-2006, 08:48 AM
cowana
Well, actually that was a guess. I thought that North America used negative, and the rest of the world used postive. In that case, it is whatever is most common.
Old 07-09-2006, 10:10 AM
exeter_acres
they both are most common.... it depends on your Radio brand....
as mentioned Futaba (and a few others) use negative shift, and JR(and others) use positive....
at least here in the States that is how it is....
Old 07-09-2006, 10:24 AM
TLH101
My Feedback: (90)
TLH101's Avatar
I have read, here on RCU, that Futaba uses positive shift everywhere, but the US. Don't how true that may be.
Old 07-10-2006, 12:52 AM
Javier Garcia
I think Futaba made it for "customer fidelity". You know what it means: incompatibility even with their own positive shift receivers. I suppose Futaba customers, specially those who had many positive shift receivers, are very happy.
Hitec and Multiplex Tx allows transmitting in positive or negative shift.
Old 07-10-2006, 02:06 PM
carrellh
carrellh's Avatar
According to the item description it works with "ALL" PPM transmitters.
It is rated for 800 meter range
Old 07-11-2006, 05:20 PM
Matthew Allen
Matthew Allen's Avatar
ORIGINAL: exeter_acres
There is no positive and negative shift in Europe - more or less any 35mhz Tx will work with more or less any 35mhz Rx.
The receiver may work fine, but like exeter, I wouldn't take the risk, except maybe for a for a small light foamy type of model, and even for one of these I'd use a known cheapo brand like GWS. Anything more complex, more delicate or more dangerous gets a better Rx. Most recent one I bought was a Hyperion DSP (same circuitry as a Berg, but on 35mhz) which is supposed to have some of the best glitch protection out there, better than PCM.
Matthew
Old 07-11-2006, 05:25 PM
cowana
Its only for a 3channel glider, so I'll take the risk...
Old 07-11-2006, 09:51 PM
Hircflyer
Hircflyer's Avatar
Remember, you get what you pay for.
