Question for hitec eclipse experts.....
Old 01-02-2003 | 01:13 PM
Default Question for hitec eclipse experts.....
I just got an Eclipse 7 for Christmas and I have been setting up some mixes for my Magic 3D. I set up a landing mix and a elevator to flap mix for square loops. The landing mix works fine but when I switch to the elevator to flap mix I get a slight up elevator and a slight right aileron movement with the sticks at the neutral position. What could be causing this??????
Old 01-03-2003 | 12:15 AM
Check the VR1 and 2 knobs and set them at center. That should clear up the aileron issue. I suspect there is a value set for ch. 2 (elevator) in some menu. You might try setting it up in another model menu so as to avoid the elevator movement.
Glen Merritt
Hitec USA
Old 01-07-2003 | 04:38 PM
Set up from scratch and the problem is gone. Must have had some value entered in one of the mixes that I didn't know about.
