CCPM mode on a JR8103?
The USA sold 8103 has CCPM, but some early models need to have it activated. This requires entering the secrete service menu, which is something that JR does not provide instructions to do.
You need to send it to Horizon for the "upgrade." Cost is about $15 for them to make the thirty second change. Oddly, all 8103's sold in Europe seem to have the CCPM mode out fo the box.
BTW, they can also do this for the XP783 transmitter and perhaps some others as well.
I HAVE AN 8103 AND THE WAY TO CHECK IS TO GO IN THE SYSTEM MODE DO THIS BY PUSHING THE UP-DN BUTTONS SIMULTANEOUSLY THEN TURN THE RADIO ON. GO TO TYPE SELECT AND SELECT THE HELI US THE +- KEYS TO SELECT THE TYPE AFTER SELECTING HELI PUSH THE UPDNKEYS TOGETHER AND YOU WILL BE IN HELI MODE. IF THE RADIO STARTS BEEPING AND SAYS WARNING PUSH THE LONG LAND SWITCH ON THE LEFT BY THE ELEVATOR D/R SWITCH TO THE UP POSITION. ONCE THAT SCREEN IS UP TURN THE RADIO OFF AND BACK ON AGAIN BY HOLDING THE UPDN KEYS LIKE BEFORE THIS TIME THERE WILL BE A DIFFERENT SCREEN AND TO THE RIGHT THERE WILL BE A SETTING CALLED SWASH TYPE SO GO THE SWASH TYPE AND SELECT THAT AND IT WILL SHOW DIFFERENT SETUPS BUT YOU WANT TO SELECT 3SERVO 120 DEGREES AND THEN IT WILL BE SET UP FOR CCPM. I KNOW I HAVE A JR VENTURE AND I HAD TO GO THROUGH ALL OF THIS ALSO. IF YOU DON'T GET THE SETUP SWASH TYPE THEN YOU HAVE AN OLDER RADIO AND YOU NEED TO SEND IT IN TO JR.
