Ground check problems?
Well I finished tuning the engine and doing those little things to get the plane ready. Now I just performed the 1000 foot ground check for the Tx and Rx. Well, I was barely about 300-350 feet away when the planes controls were glitching and then they stopped. Both the Tx and Rx batteries were fully charged. Any ideas what this could be? Thanks in advance.
Originally posted by Steve Guinn
Those other guys weren't lying to you.
As for my model. Its glow, the antenna was extended. The antenna routing...I took it out of the Rx, wrapped it once with foam rubber, placed the antenna lengthwise on the foam rubber and overlapped it again so the antenna was between two pieces of foam rubber. Then i routed it out through the hole.
As for how I could see the control surfaces at 1000 feet...my dad was controlling the Tx while i was 1/5 mile away
You took the antenna out of the Rx? I don't understand.
Anyway, the receiver antenna should be fully extended. It should not be doubled back on itself.
It does not need to be covered in foam.
Many people route the antenna to the top of the vertical stabilizer. I prefer to tack glue (hot melt) in a couple of spots to the bottom of the fuselage.
The Rx should be wrapped in foam, not the antenna.
I think I finally understand your description. The antenna is fully extended, but runs between two layers of foam as it exits the receiver.
This should be fine.
Do a range check with the antenna down. Walk 100 ft. away and check your control response. If they work properly, put your antenna up and fly the airplane.
Good luck,
Steve
Good luck,
Steve
Re: Ground check problems?
hold the plane over your head.
It seems that you may have place some stress on that RX antenna wire.
No need for all the foam.
Keep it in the clear.
With the TX antenna shoved in you should get an easy 100 feet and if the RX is close to the XTAL frequency you may even get 150 feet.
If you can't get the proper range check then don't fly.
Remember from my last note to you.
When you operate the TX you pull current from the batteries and a bad pack could do just what you have now.
Keep us posted
