Reset main timer on 7c
Old 01-13-2008 | 04:44 PM
Default Reset main timer on 7c
Is there a way to do this? Thanks.
Old 01-13-2008 | 07:23 PM
Default RE: Reset main timer on 7c
From the 7CAP manual:
Adjustability:
• Count down timer: starts from the chosen time, displays time remaining. If the time is exceeded, it continues to count
below 0.
• Count up timer: starts at 0 and displays the elapsed time up to 99 minutes 59 seconds.
• Independent to each model, and automatically updates with model change.
• In either TIMER mode, the timer beeps once each minute. During the last twenty seconds, there's a beep each two seconds.
During the last ten seconds, there's a beep each second. A long tone is emitted when the time selected is reached.
• To Reset, choose the desired timer with the SELECT key (while at the startup screen), then press and hold DIAL for 1 second.
• Activation by either direction of SWITCH A-H, bySTICK (1-4) . THROTTLE STICK is convenient if you are keeping track of fuel.
• To quickly reset any timer from the home screen, cursor down until the timer blinks. Press dial to reset.
This is on pg 37 if you have the manual handy.
Old 01-13-2008 | 09:30 PM
That one did it. Thanks!!
PEACE
Old 01-16-2008 | 06:43 AM
i have a spektrum 5 channel radio which igot with my blade cx2.is that compatible with an rc airplane.if so please tell me how
