Futaba 6014 receiver heat issue
#351
VA
RE: Futaba 6014 receiver heat issue
ORIGINAL: xcellheli
SManMTB,
I think the point is your manual was written before Futaba knew they had a problem. It is not in your manual and there is no way of you knowing there was a heat spec before buying it. I would argue even if it was in the manual you most likely would not have known you had a problem since I doubt you have taken temp data of the radio box on your car before. Everyone agrees that you unfortunately got hit by this specification. Many have offered advice toward a solution. We all know how you feel about Futaba, now get over it. It sucks, but life goes on. If you fix your issue, post your solution. Otherwise just drop the complaining. It is not constructive.
This thread has reached the point of being worthless.
SManMTB,
It's worth complaining until the manufacturer does right, and it seems they started to do so with the 10C.
Peace and good luck flying.
#352
SManMTB
Best I can tell, Futaba has admitted there is a problem. They admit the Engineers in Japan are working on it. I assume when they are satisfied they have improved the situation they will make an anouncment. In the mean time Futaba has given mounting suggestions to help avoid the problem all together. And now they are updating literature to let the consumer know the temperature the equipment should safely be operated in.
I assume they have read your failure and have noted it.
What else are they not doing that you think they should?
I am not trying to bash you, but so far I am satisfied with the progress Futaba is making (Of course I am not happy the problem exists at all), but you don't seem to be satisfied. I am just curious.
#353
i'm not sure what Futaba is suppose to do at this point.
if one realizes that the cutoff temps in a normal installation are occuring, then either that person is capable of surviving Moonwalks without a protection suit, or they just don't have the sense to come in out of the rain either.
if as you say that the competition car circuit has been able to produce ledgeable issues under normal operating conditions, then i would agree that Futaba has some work to do..............what documentated issues have been presented to Futaba to show them that their equipment is bunk?
#354
ORIGINAL: summerwind
I wonder if somebody went out a flew in a pouring rain and then crashed if we would be ready extended threads about how Futaba has failed to engineer their radios to work in the environment that the pilot chose to fly in.
#355
VA
#356
VA
ORIGINAL: Silent-AV8R
This may be true since most all of the manuals for Futaba radios clearly state not to operate the radio in the rain.
But maybe you're right!? Maybe an IP rating for the radio would be good too. LOL
#357
IL
I'm not sure what Fubuta should do but I know what I can do. Last mouth when I received my new 10C I sent it back. With all the problems being talked about it just didn't make sence to keep it. It does not make sence to sell a 14C RX with a 10C TX radio.
#358
#359
My Feedback: (243)
ORIGINAL: dilled
So I am as comfortable with my choice as you are with yours and I am completely satisfied with Futaba's position on the issues tossed about on these threads, real or perceived.
However I will say you are missing an outstanding value in the 10C and you may want to revisit when the 10 channel FASST receiver becomes available, or just stay with 72mhz PCM. Although 2.4ghz is trendy right now it is emerging technology within our hobby and may not fit all of our wants nor be wrinkle free. I switch between the two thus utilizing all of my equipment, new and past, that has proven 100% reliable for me.
#360
CO
I have tested my stuff out and found one of my BECs failed before the rx.
HOLLY CRAP I don't even get to go into failsafe, the power source to the rx died.
Lets start a big long thread on the BEC manufacturer.
I have a power expander and it has temp rating also.
My rx's work to 157F with soak time.
Ran out of time for more testing.
As the technology of the silicon used in the IC's advances, we must keep up with it also.
This means unless we use mil spec stuff we need to be more aware of thermal and voltage concerns.
WE the CUSTOMER want inexpensive stuff and one way to get it is not go with
Mil spec stuff but use commercial stuff(much cheaper and lower temp ratings).
I see threads complaining on prices and the manufacturer has to cut costs somewhere
to keep the costs down. In some ways we are our worst enemy.
Still continue to fly my 14MZ 72/2.4 with confidence. For me the lower temp range is not a problem.
I still find it amazing with this and another long thread there is not more reports of problems.
I too am concerned with the temps we can encounter, thats why I tested mine to see limits.
I have a eagle tree logger for in the planes and check parameters when new setups that I have a concern with or just
want to know the data/info.
#361
My Feedback: (243)
ORIGINAL: tkilwein
In my opinion we don't get more reports of problems because there arent' many. There can be real problems with new equipment and technology but it is the hypothetical or rarity that gets over hyped and bloated by a noisy few. Until there are forty or fifty consistent valid complaints about a product I discount it and chalk it up to the occasional manufacturing defect.
Futaba's position, and their equipment, is fine with me.
#362
VA
Spoken like a true Futaba representative.
If 10% of all RC'ers read RCU (like you said) we are already up to 40 or 50 consistent reports.
#364
My Feedback: (16)
CA
ORIGINAL: Flyfalcons
Let me get this right, if someone speaks their opinion and you don't like it, that makes them a company rep?
Don't worry 'bout it
#365
talk about beating a dead horse to a bloody PULP........this thread is a must read for those who enjoy comicals...................i think the real problem here and has been all along is user error.
it seems that every product on earth can and will be used by someone who is basically a common MORON, and will indeed figure out a way to shoot their own Toe off and then cry FOUL...............which will then post a "Buyer Beware" topic somewhere on the net to which all other included Morons of the same category will jump in with all fins flappin'.........funny stuff
#366
VA
Let's set everything straight. When I speak my opinion Mr Dick Fanboi doesn't like it and becomes childish. Where is the difference here.
Why are you defending a blowhard like that. Are you his associated dingleberries without a mind of your own.
This thread is pure comedy.
#367
VA
It is really funny. That's why this country has so many stupid lawsuits too. It is also the reason manufacturers specifies how to use their stuff. No fun being sued is it?
#368
QC, CANADA
I am amazed.
After more than 300 postings...
This thread started because some flyers discovered that their 6014 will malfunction at high temperatures.
Some people, over time, reported no problems.
Eventually Futaba, by means of a Baxter posting, gave 1/4 of a answer describing how to set the receiver in the plane. I think implicitcly admitting that there was a problem.
Futaba itself has not acknowledged the problem or have stated clearly that there is no problem. I must here recall the famous poisoned Tylenol scare of many years back: the company reacted promptly and removed the product from the shelves. Tylenol is still selling today, very well I think. The way the case was handled by Tylenol was quoted for years in business publications: better to act than to let it fester.
Another Futaba faux-pas was the admission that the signal voltage in those receivers was lower than habitual.... after they have sold many of them, not before. And the recommendation was to use... a power expander.
And now, the result of all this is that we, the flyers, the users of the product, are biting and snarling to each opther instead of concentrating in the reported problem and lobbying for a definite answer from the manufacturer.
It is also somewhat possible that problem reporting in some products, be it Futaba, JR, Spektrum or whatever are marketing campaigns by competitors. The Internet is fantastic in creating a community of people with the same interests but not very good at separating the grain from the chaff.
#370
ORIGINAL: SoCalSal
Company rep or as they say over at Fl*ing Gia*ts a FAN BOY
#371
VA
Ah, I see. Can't argue with facts so you start calling names. Got it.
ORIGINAL: SoCalSal
