modify Futaba T4VH skysport
Dear Seniors,
Same Q asked again, I bought Realflt G2 lite to practice heli, left stick throttle/rudder and right stick is elev/aileron. Good. comfortable, i bought Mini Dragon and supplied with Futaba 4 skysport but left stick elev/rudder and right stick throttle/aileron. How to modify the futaba wiring to match the transmitter mode USA. It is easy to change the Realflt controller to adopt the US style
thanks :drowning:
thanks :drowning:
Hi runover1,
Thanks for the suggestion. I successful switch over the Realflt controller's spring and metal clip?? to the arrangement to suit the futaba skysport asian layout mode. I m not quite happy because it is somewhat not logical to have Elev/Rudder on one stick and Throttle/ Aileron on the stick. Though I could practice it and a matter of time I would be at home on the asian mode. Logically,as in the actual aircraft the effect of throttle up is yaw compensate by rudder and elevator and aileron 'mixed' to produce desired path. I have some background in electronics hobby so i m trying to get best suggestions. Anyway I ll open up the futaba to see if could swap it without extending the connecting wires.
Thanks runover1
Thanks runover1
Moderator
My Feedback: (58)
Hi shohimix, here are a few links to T4VF modifications that might be useful to ya. I used the 4VF as a buddy box and use it sometimes for my Aerofly Pro flight sim, although I use my 9C mainly. Hope this helps. It involves some basic soldering steps, and a DMM will be useful. Good luck.............
http://www.rcuniverse.com/showthread...ighlight=rajul
http://www.rcuniverse.com/showthread...613&forumid=27
http://www.rcuniverse.com/showthread...973&forumid=27]
Thanks rajul,
I ll have a peep at those sites. Certainly, at least it will very useful for future projects on my T4VF. Will let you know.
thanks for the post
thanks for the post
