Can i use an airplane radio/reciever on a boat?
I have an extra 2.4 reciever transmitter and I just got a Blackjack 26 BL boat. The transmitter and reciver that came with the boat suck. Just terrible. If I go 2.4 then I can seal the top onto the boat.
Thoughts? I'm only going about 100 yards away at the MOST.
CA
RE: Can i use an airplane radio/reciever on a boat?
I dont see why not, as long as you set it up and be sure all the servos function properly relative to the stick movements. The only issue I see that might happen is that the left stick on an air Tx doesn't have a spring return on the Y-axis (up and down). It starts all the way down and gradually increases upward and stays where you have it. If your boat has a "reverse" function then you would need to modify the Tx with a spring loaded 'center return' on the left stick. Also, if the Tx/Rx system have a failsafe feature it probably cant be used. Reason being, if you lose signal or power the failsafe will return the throttle to the "0" position, which in your case would be full reverse.
To test this hookup the receiver to a battery supply and spare servo. Center the left throttle stick and then turn off the Tx. Then turn the Tx back on. If the servo moves back down it has a failsafe and will not be suitable. If the servo stays where it is and you can again move it with the stick movement then you're good. (If the boat doesn't have a reverse feature then you're fine as is, you don't even need to modify the Tx with a spring return).
I'm not a boat guy but the concept is the same I believe when it comes to Tx/Rx and servo movement. Maybe you can find a boat person on here answer this question better for ya. Good luck!
Thanks for the reply. The ESC onthe boat has no reverse. So it sounds like I'm good. I'm guessing that the 2.4 will work on the water as well, if not better than, 72MHz.
One way to find out.
CA
Oh yeah. The 2.4GHz will be great. Way better than the FM you're using. You'll lose sight of the boat before your radio stops controlling it. No radio interference either, say if you turn on your boat before your transmitter, your servos dont start squawking.
You can use 2.4 on any type RC. You can only use 75MHz on boats and only 72MHz on aircraft . Water can adversely effect 2.4 more so than 75MHz but if you keep the active portion of the antenna (that last few mms) as high as you get it on a boat, you will probably be okay.
ORIGINAL: Rodney
By antenna you mean the one on the reciever?
The radio that came with this unit is garbage. I've bought toys from walmart with better range.
ORIGINAL: Supervetteracer
ORIGINAL: Rodney
ORIGINAL: Supervetteracer I have an extra 2.4 reciever transmitter and I just got a Blackjack 26 BL boat. The transmitter and reciver that came with the boat suck. Just terrible. If I go 2.4 then I can seal the top onto the boat. Thoughts? I'm only going about 100 yards away at the MOST.
Many are prone to problems with shadowing behind other boats, especially yachts and ground effect.
Distance of 2.4gHzover water is much less than high in the air as tip of RX antenna can not be raised as high as the older systems so as to get out of ground effect.
FWIWSpektrum, Spektrum Marine Article provide a separate system for use with GP/EP boats, and their web page makes no mention of yachts or use in a crowded area at all. Perhaps they alsoexperience the sameshadowing problems (loss of control when one model passes behind another)as locals who have triedDSM and similar systems.
AFHSSAFHSS in operation -Video appears to be the least effected by masts/superstructure etc of other boats and easy to install so as toavoid the problems with carbon fibre hulls/masts.
AFHSS Telemetry - Range test Using Segway & GPS - Video - Demonstrates remarkable 2100+ft not only through large obstacles but also with Heli sitting in ground effect. - this would be less over water.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
10Jul10 PS: another thread
