starter box conversion
CA
RE: starter box conversion
There is really nothing to do but get the box, if you want to remove the pull start you can buy a cover to replace all that stuff
[link=http://www2.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=Pull+Start+Cover&FVPROFIL=++]Starter Cover[/link]
CA
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLZ9&P=7]Starter Box[/link]
This box will work on most any car
I use this from home depot mine was $40.00 12volt system you can run anything 12volt or just use car battery
ya that is kool, thanks. On your car did you take off the pullstart or did it not come with one or do u still keep the pullstart on?
NY
it doesnt really matter but if you put a cover on and you dont have your starter box your screwed. The advantages to a cover is that it is suppose to give you higher rpms -not by much though- and will shave maybe a tenth of a second off your lap time if you race. But if yo dont race keep the pull start.
CA
I still have pull start on off road RC10GT because i dont race it, but i use the box to start it
My nitro rustler i took all the starter stuff off (because it quit) put the cover on and use box
My on road cars dont have pull start so they have the stock cover on them
I only use the pull start to prime the engine and run after run oil in
Just have fun anyway you do it
ok, does anyone have a clue where i could get a cover for my wasp .12 se-ps? I looked on tower and they didnt have it
