Bumping Flywheel To Stop Engine Debate
I was just wondering out of all the ways to stop an engine I agree that pushing in the air filter is the worst. There are of course safe ways such as pinching the fuel line but I rather burn off all the fuel out of the lines if there's little left. Does anyone agree with bumping the flywheel for instance with their shoes to stop the engine? In my mind this puts more strain on the engine internals such as the con-rod and make them more susceptible to wear and damage. What do you guys here think about this?
CA
RE: Bumping Flywheel To Stop Engine Debate
I cover the exhaust tip. No strain, just a slow stall. No leaning or flooding it, both of which are bad. Very bad. [:'(]
My Feedback: (-1)
ORIGINAL: armedtotheteeth
CA
Taping the fly wheel is the best way to stop the engine. I think the NTC3 manual even says to do this and it says not to cover the exhaust tip.
doesn;t plugging the exhaust cause a whole bunch of fuel to be thrown into ur engine, making it hard to start next time round?
I pinch the line, and the empty out the fuel tank, and attach the glow warmer again and start it up, and it just runs for a couple of seconds burning up whats left
leans it out? for about 0.5 of a second... bumping the flywheel with ur shoe or something could be dangerous, and it sounds like it would put a lot of stress on things... piston and conrod moving very quickly... then coming to an abrupt halt..
FL
ive always just pinched the fuel line and it hasnt caused any problems on my car or so i think[X(]. except once i think it was only the second time i used a gas rc car and i really had nno clue, i read in the book to emergency stop the engine stop the fly wheel and i went to do just that and i got my finger burned
My Feedback: (-1)
ORIGINAL: Frank88888888
Lesson learned: Be cool and dont read the manual.
FL
damm! 2 minutes are you serious or exaggerating?
i even knew the first time (no nitro experience) and i just riped that fuel lines off when my Chrystal fell out and truck was at 1/2 throttle
Banned
My Feedback: (7)
TX
dude that looks trashed, i bought a fail safe a long time ago, i accidentally started the car on the starter box without plugging the reciever pack in and the car ran for a about 8 secoonds at WOT, i tried plugging the reciever pack in but i could get it in right so i just pushed the throttle back down with my finger and plugged it back in, i dont think any damgae could of been done for only 8 seconds but ill never know until i take the head off wich i really dont feel like doin
My Feedback: (-1)
ORIGINAL: losi xxx-ntkid
NJ
covering the exhaust stinger floods the engine putting exess strain on it even more than bumping the flywheel. Its like moving ur hand through water then suddenly its turns to molasses. that would put a lot of strain. The fuel line isnt the worst as it jus leans it out for a short time...just make sure its a idle or the rpms are sumwhat low when u do it. The air filter way which ive hear about floods the engine too so thats like the stinger concept basically. The flywheel(most likely the best way) and the fuel line thing are the two ways that wont flood the engine which makes em better....really.
FL
The HPI RS4 3 EVO manual says that only under emergency conditions should you pinch the fuel line. They say the best way is to plug the exhast with a rag.
My Feedback: (34)
IN
Over the weekend I did some servo trim adjustments on my cars in preparation for this weekends racing. I tried the flywheel method, it really only took a touch to stop the engine, I was surprised.
FL
ORIGINAL: Burntt32
i hope thats not your engine?
