Ofna cd3 pro
My Feedback: (29)
Ofna cd3 pro
I'm getting an Ofna cd3 pro soon. Anyone raced this car yet? Just wanted to know some handling characteristics. Foams the carlikes and such.(shore front and rear) The track I run on is a hair on the bumpy side and a little dusty at spots. Lmk some of your setups if you got them.
CA
RE: Ofna cd3 pro
i was going to get one but instead i got the gpx4. it's a great car from my ofna experience. i raced an LD3 and it was able to keep up with any other car out there. the cd3 is supposed to be even more sensitive to suspension adjustments. so i'm sure you'll definitely find a set up that works. i typically run 35wtoil front and rear shocks. i use the blue springs (medium) in the rear with yellows (medium-soft)in the front. i run anywhere from 35-37 shore front tires to 40-42 shore on the rear. about 2-2.5 deg negatice camber all teh way around and from 4-6mm ride height. usually a tad bit higher in the rear to compensate for tire wear.
