Err Help..
NY
Err Help..
I was about to do a nice little motor swap. Got all 3 screws loose.. The FOURTH SCREW HAD TO BE STUCK.. Won't budge I lubed it even tried WD-40.. It's like the screw is just stuck.. Anybody have any other ideas..
Thanks In Advance.
Thanks In Advance.
RE: Err Help..
Also trying twisting the engine a bit to see if it'll loosen it. You might just have to use a lot of elbow grease though...
Never fails..
Never fails..
NY
RE: Err Help..
Thanks to all..
The hair dryer technique worked the best of all.. In the end I got the engine out. When I twisted it long enough it broke.. Cleanly.. I read on the hpi website that you make all most any engine Roto-Start.. So I removed it.. There right I put it on an old engine I had on a truck and it works quick.. I recommend it to all. When I finally get O.S. I will do it to that one as well..
