What os 18 tz should I get?
FL
Eventually I wanna get a os 18tz with a pull starter for my HPI rs4 super nitro. Can someone give me a model number please? so I know which one to get.
FL
RE: What os 18 tz should I get?
Thanks for the info, but will os 18tz tx driveshaft fit with my super nitro rs4
http://www.hpiracing.com/kits/rtrsuper/rtrsn-m.htm
CA
You can also re-drill your motor mount holes through the aluminum chassis if needed (left or right).
Just don't get too close to the pulleys or the fiber disk brake (make sure they don't conflict).
You can actually get pretty close.
FL
IS THAT THE 2 SPEED CLUTCH NUT FROM THE NTC3
http://www2.towerhobbies.com/cgi-bin...?&I=LXBMD5&P=7
OR
http://www2.towerhobbies.com/cgi-bin...?&I=LXBMD6&P=7
OR
FL
haha sorry, he was the one that was online at the time. thanks for the info ferrarimk13
so os .18 tz-tx with the first above nut. Right?
NY
yup, u can use the stock clutch, or get a new one with a lightweight flywheel, which works great btw.
here is a pic of mine in the chassis (RS4 3)
ORIGINAL: ByronRC
Anyone? GYNAIKAS I'm looking your way?
FL
Can you use an rs4 3 clutch gears in a super nitro rs4 2? I didn't think the were interchangeable. If so please let me know how.
CA
Yes, the RS4 3 gears are the same pitch and work with the RS4 Super Nitro & RS4 Racer 2, two speed tranny.
Thanks to Got to 100 for that helpful bit of advice.
You will need to purchase the RS4 3 clutchbell, bearings, etc. I recommend printing out the RS4 3 clutchbell assembly from the HPI site and making a plan for the parts you will need to complete because depending on the length of the SG shaft, you will need to find the right flywheel, clutch, nut shaft extenstions, spacers, etc.
But don't let the spacing get you down, its all within the realm of figuring out.
The red 23T gear is the tallest pinion you can get for the RS4 3.
Here is the combination that gives you the tallest gearing and still allows good mesh betwen 1st & second gears.
1st: 18T pinion (gold RS4 3) /43T spur (RS4 2 & Super Nitro)
2ns: 23T pinion(red RS4 3)) /37T spur (RS4 2 & Super Nitro)
Don't settle for the clutchbell with 1st & 2nd pinion welded into one that's provided as standard with the Super Nitro & RS4 2 two speed tranny.
ORIGINAL: ByronRC
NY
its alittle under 60 id say, maybe 58, but it gets there instantly, and revvs pretty high, i like it, but break in is a pain, theres so much compression.
