Peak racing .12
PA
Peak racing .12
Just got one from a friend and I want to put it on my hip rs4 rtr3 evo. Anyone know a good header and pipe?Also what I will need to make the clutch set up work on the new engine? thanks.
NY
RE: Peak racing .12
u will need the NTC3 clutch nut http://www2.towerhobbies.com/cgi-bin...?&I=LXBMD5&P=7 and look at THS for the pipe and header kit for the RS4, thatll be perfect, and the performance will also be very good.
PA
RE: Peak racing .12
Thank for the reply. How much faster do you think it will be? And should I change the gearing because I know that .12 will turn alot more rpm then the t15 that's on it now.
RE: Peak racing .12
I know they do but they're the best and they really achieve stready and continius pressure at the fuel line + they give engine more rpm and hp. Since he's talking about a .12 engine that should be the perfect choice and he can also use the pipe to a future better engine he might get (RB,Sirio etc.)
CA
RE: Peak racing .12
ORIGINAL: ferrarimk13
ohh, i see, i guess ur right, but im not sure if hes willing to spend the $100 on a $50 motor, but its up to him.
It can be seen several ways. A .12 is a small engine, suceptable to subtle tuning changes. A pipe on an engine like this that gives the gains discussed above will provide the most driving enjoyment. A smooth torque band and reliability are priceless, after hours of stalling.
The great thing about the pipe is that it is an investment. It's not a single time expenditure (unless he crashes and breaks it), it can be used with other .12 and .15 engines, and on other cars. That single purchase is easily a multi-time benefit.
