Best engine for a TGX
What is the best engine for a modded TGX? everyone says the 18TZ is the best engine you can get but I am worried that the high torque will destroy the drive train, also why do you want a high torque engine for on road cars?. Is there a better engine or should I just get the TZ? I am after all out speed for bashing not racing.
RE: Best engine for a TGX
It's you who asked for the best...so tz is the best...now as for the risk of harming your drive train go to heavy duty parts.
ORIGINAL: GYNAIKAS
Can you post any pics of the tranny, the mounting positions and the car (without the bodyshell on) so I can estimate the Hp it can handle?
NY
are u talking about the .12 or the .18? they are both great motors, but if you have a 1/8th, go with a .21, it definitely should fit.
I don't have any pics of the car but there are a few around on the net, they are 1/8th but it is more comparable to HPI's super RS4 then a 1/8th circuit car or buggy so a 21 will definately be over the top. It came as standard with a 15 size engine but it is a very old car now (10 years or more) so the engine is a poor design by todays standards. The drivetrain is prop driven, with plastic spurs, metal diff gears, front one way bearing diff the drivetrain is very advanced for the age of the car and is similar to the TC3 but stronger and bigger. I have the uprated propshaft which I can't see any 18 size engine breaking (basically a 5mm stainless rod) but I suspect the spurs are not made for serious amount of torque as they are quite small for a 1/8th car. The only reason I haven't just settled for the TZ is because I wanted to know if there was an engine out there that would have enough torque to move this car but not so much as to rip it up but with as much revs as possible. I have looked at the RB engines, but they don't give dyno figures because they say you can't compare engines based on them and also the Novarossi engines and they have the NS15 which is claimed as 1.8bhp and 43,000rpm practical revs but they are hard to find and seem to be 'big block' so i guess they wouldn't fit.
