MY NITRO 4-TEC 3.3 CUTS OUT AT HIGH HELP!!!!
My nitro turns on fine... but when i accelerate gently it shuts off i've richend it, let it idle to warm up but it still shuts off. It also shuts off at high speed and there's a weird clicking sound but i dont know where it's coming from....help anyone...
RE: MY NITRO 4-TEC 3.3 CUTS OUT AT HIGH HELP!!!!
Try adjusting you Low end screw on the end of the carb slide trun it a 1/4 out just remember where you stated i just got a new 3.3 motor and it had the same problem
Sounds like its too lean to me, first try richening up your high speed needle(turn counterclockwise 1/4 to 1/8 turn at a time) to see if that doesnt help anything, then go back and re-adjust the low speed needle. See if thatg helps ya out any. Hopefully this will
